im goin 2 put a new clutch in my rb25det (neo if that makes a differecne) since i have everything out
i was talking to the bloke at the clutch shop about it and he suggested a brass button clutch with 6 buttons over an organic one, because if you give it a squirt regularly i would wear the organic clutch away very easily... i was concerned about the driveability and durability of the brass button clutch... how long does this clutch last and when it does shit itsself will i need to get the flywheel re-machined... also how hard is it to drive in traffic... i want it to be a nice to drive car not kangarooing up the road because of this clutch
thanks everyone & have a good x mas
Edited by Space Goat
https://www.sau.com.au/forums/topic/99403-clutches/
I went to a clutch specialist here in canberra, and what clutch they suggested to me, i got. Ended up being $854 fitted for an excede clutch.
You need the fly wheel machined, otherwise it wont mesh correctly 80% of the time (you get mad shudder).
You'll adapt to the brass button clutch, and it might be a little heavy to start off with... but will pay off in the long run. Mines an organic clutch, and at first i was very hoppy with it:) Now i can launch it very nicly.
Dayne
https://www.sau.com.au/forums/topic/99403-clutches/#findComment-1812198
nar pretty much stock neo motor... will run standard boost for now but will upgrade turbo when this one shits its self... modifications will be usual stuff 3" zorts, pod, chipped ecu. ect ect might get it port matched to improve flow later on aswell as a arc smic and some sort of crazy computer (still undecided)... but for now just want to get it running reliable and stock so i get used to the power of the neo
also driveability in traffic will the 9 button clutch be smoother than a 6... i dont want it to be a pain to drive in traffic
https://www.sau.com.au/forums/topic/99403-clutches/#findComment-1813023
get a jim berry clutch, spoke to him and can still retain alot of driveability and no aching left leg after driving and mine has just under 400rwkw which he says this particular one will be fine for it..
ask adrian (2rismo) he used jim berry clutch, its a perfect feel daily driven clutch and he runs 11s
ben...
https://www.sau.com.au/forums/topic/99403-clutches/#findComment-1816108
I've just recently replaced my exedy HD clutch with a brass button clutch with 6 buttons. I think the driveability of the brass button clutch is actually easier and smoother to drive with day to day around town than my old clutch. Both are very heavy on the left foot but u get used to it.
I was told that the brass button wouldn't last as long as an organic but organic clutch heats up and begins to slip after a few launches. So far, button has been great. Bout $100 more.
Can't tell u how long gonna last though....
https://www.sau.com.au/forums/topic/99403-clutches/#findComment-1816748
ben...
I got one too. Dead set awesome clutch. And one of my mates has a full custom one from him in his 3sgte corolla.
Very bitey, but so soft to the foot.
To get his number just google his name. At least give him a ring.
https://www.sau.com.au/forums/topic/99403-clutches/#findComment-1816770
I'm using xtreme 9 puk. I'd buy it again.
Organic = weak if you're running 200rwkw IMO.. plus heat = no take up. Organic is what people should use in a STOCK car.
If you're running extra boost I would suggest atleast a setup similar to the xtreme 9 puk with 860kg pressure plate. Cubes runs the same clutch with 1100kg pressure plate with his rb30 and he's only said good things.
I wouldn't bother with a brass button as it's old school. Just get a sprung centre with 9 or 6 puks (the less puks the harder the pickup will be) and you'll be right.
Having said that a lot of people will say using a brass button you'll get used to it - which is true, but why make it hard for yourself when you don't need to?
https://www.sau.com.au/forums/topic/99403-clutches/#findComment-1818909
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
