hey guys i just bought a std r32 gtst (only pod n 3 inch exhaust) n a mechanic said its been boosted well above 7psi n i dont have a boost controler to turn it down, even on low trottle the boost runs very quick to show reading over past the factory boost guage of 7psi, if im runnin this high boost for long,
a) what damage could it be doin to my engine n turbo since i dont have a front mount or any other mods for sufficient airflow cooling for the boost level (prob 10/11 psi)? if so what would be a safe boost level without puttin a strain on the engine without the frontmount?
B) what would be the cheapest n best way to fix the problem? (maybe turn the boost back down with a manual boost controller)
c) would a bleed valve help?
d) i also get 300km on a 42l tank with only some racing, is this decent?
thanks guys for any help you can give me.
https://www.sau.com.au/forums/topic/99407-plz-help-too-much-boost/
If its showing 7 on the factory guage, it means its running over 14psi as the factory guage uses different units to psi.
The only way it can run more then standard boost is if the wastegate actuator has been changed, its stuck partially closed, or it has a bleed hole or split in the hose between wastegate actuator and the turbo compressor cover.
Check that first.
11-13psi is FACTORY :lol:
No its not
Factory is about 7psi, with a full 3inch exhaust and pod it will creep to 10-13 though, I know mine did.
Theres no way to turn it back down without getting a different spring. A boost controller will only allow you to set it higher then what you currently have. Id just take it easy on the hot days and get a FMIC so it doesnt cook the air. If its really going up to 14psi Id get the spring/actuator checked as somethings wrong there and it'll kill the turbo pretty quick smart and really cook the air.
does it still run good?
if so get a turbo timer and enjoy it i say.
With the standard turbo and intercooler anymore then 12psi will just cook the air making the engine more likely to ping (bad) and not give any power increase, I wouldnt recommend leaving it like that with summer coming up.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
