hey guys i just bought a std r32 gtst (only pod n 3 inch exhaust) n a mechanic said its been boosted well above 7psi n i dont have a boost controler to turn it down, even on low trottle the boost runs very quick to show reading over past the factory boost guage of 7psi, if im runnin this high boost for long,
a) what damage could it be doin to my engine n turbo since i dont have a front mount or any other mods for sufficient airflow cooling for the boost level (prob 10/11 psi)? if so what would be a safe boost level without puttin a strain on the engine without the frontmount?
what would be the cheapest n best way to fix the problem? (maybe turn the boost back down with a manual boost controller)
c) would a bleed valve help?
d) i also get 300km on a 42l tank with only some racing, is this decent?
thanks guys for any help you can give me.
https://www.sau.com.au/forums/topic/99408-plz-help-too-much-boost/
The stock R32 turbo can run on 12psi all year round. It's when you push pass this mark that it starts to faulter. You'll find if you were to put a larger intercooler on, it'll drop back down to around 7psi.
I think you should go back to elbee's post, the stock gauge is in mm/Hg which is about half of PSI. So 7mmHg is about 14psi which is pretty high.
Stock boost is 10psi, and like ruffryder said you'll often get 1-2 extra from an exhaust. but 14psi or higher is too much to run regularly on a standard turbo, and might be causing pinging too if you have a standard motor and standard tune.
Get a dyno run (about $40-40) and get it checked out
thanks man but yea wen i push the car the stock boost gauge reaches to the top right away and you can still hear the turbo spooling up after that, so this would most definetly be runnig more than 12psi according to your reply? if so can i just burrow my mates electronic boost controller to turn down n give it back to him or do i need to get one my self?
just on the issue of fuel consumption, i think that 300km to 40 l of fuel is reasonable, my stock standard engine takes roughly 50 litres to 375 k's, and thats ALOT of hard driving (many 6000 RPM gear changes)... but i havent had my car dyno'd so i dont know if its running at normal power though.
i thought that the stock rb20 turbos were supposed to run at 4 psi???
cheers. james.
umm are u reading from the standard boost gage? cuz there very old and unreliable... what i suggest u do is buy a boost gage hook it up then read what your running... my car run's 10 - 10.5 psi.. i have zorst, pod and a bov... so get a new gage from auto barn 80 bucks.. comes with everythign to install...
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
