hey guys i just bought a std r32 gtst (only pod n 3 inch exhaust) n a mechanic said its been boosted well above 7psi n i dont have a boost controler to turn it down, even on low trottle the boost runs very quick to show reading over past the factory boost guage of 7psi, if im runnin this high boost for long,
a) what damage could it be doin to my engine n turbo since i dont have a front mount or any other mods for sufficient airflow cooling for the boost level (prob 10/11 psi)? if so what would be a safe boost level without puttin a strain on the engine without the frontmount?
what would be the cheapest n best way to fix the problem? (maybe turn the boost back down with a manual boost controller)
c) would a bleed valve help?
d) i also get 300km on a 42l tank with only some racing, is this decent?
thanks guys for any help you can give me.
https://www.sau.com.au/forums/topic/99408-plz-help-too-much-boost/
The stock R32 turbo can run on 12psi all year round. It's when you push pass this mark that it starts to faulter. You'll find if you were to put a larger intercooler on, it'll drop back down to around 7psi.
I think you should go back to elbee's post, the stock gauge is in mm/Hg which is about half of PSI. So 7mmHg is about 14psi which is pretty high.
Stock boost is 10psi, and like ruffryder said you'll often get 1-2 extra from an exhaust. but 14psi or higher is too much to run regularly on a standard turbo, and might be causing pinging too if you have a standard motor and standard tune.
Get a dyno run (about $40-40) and get it checked out
thanks man but yea wen i push the car the stock boost gauge reaches to the top right away and you can still hear the turbo spooling up after that, so this would most definetly be runnig more than 12psi according to your reply? if so can i just burrow my mates electronic boost controller to turn down n give it back to him or do i need to get one my self?
just on the issue of fuel consumption, i think that 300km to 40 l of fuel is reasonable, my stock standard engine takes roughly 50 litres to 375 k's, and thats ALOT of hard driving (many 6000 RPM gear changes)... but i havent had my car dyno'd so i dont know if its running at normal power though.
i thought that the stock rb20 turbos were supposed to run at 4 psi???
cheers. james.
umm are u reading from the standard boost gage? cuz there very old and unreliable... what i suggest u do is buy a boost gage hook it up then read what your running... my car run's 10 - 10.5 psi.. i have zorst, pod and a bov... so get a new gage from auto barn 80 bucks.. comes with everythign to install...
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
