General Power Output - RB26
Guest Nismo_Freak
Decided to just dump the 26 into the 240SX (200SX).
Heres the mods I will be running:
R32 GTR Motor (Possibly R33)
R33 RB25 Tranny
Aluminum Single Peice Driveshaft
Hardened 4.11 Rear End Gears
Kaaz 1.5-Way LSD (still debating which to use)
Blitz Skyline FMIC w/ Custom Piping
Apexi Intakes w/ Cold Air Induction (try to encase the filters w/ box, if not I'll just duct ambient air)
Blitz SBD iD Boost Controller
Blitz Auto Timer
3" Custom Downpipe to 3" Blitz NUR Spec Exhaust (no cat)
Haltech E6K Engine Management (moderately tuned for power, still want car to be somewhat reliable)
255Lph Walbro Fuel Pump
RX7 Oil Cooler
I believe thats about it for the mods. Im going to use stock turbos for a while and later upgrade to twin HKS2530s.
I'd like to run about 1 bar if that is safe on the fuel system. I very open to opinions and suggestions. Let me know how this stuff works out on your GTRs.
I'd like to get an estimate of what kind of power I would see at maximum SAFE boost levels. I'm perfectly willing to sacrifice power to maintain safe engine operation.
I need a suggestion for a clutch as well.
Thanks guys!
https://www.sau.com.au/forums/topic/9942-general-power-output-rb26/
Guest Nismo_Freak
Figured since the 2530s can flow around 320 ps each I would get around there. However I was more or less wanting to know what I can acchieve on stock turbos. Also what kind of boost limits I would see with the stock fuel system (w/ 255 lph fuel pump) and stock turbos.
I think the most you can get out of stock turbo's is 400hp'ish don't quote me on this..
As for your fuel just because its says its 93 octane doesn't mean its worse then ours, in the states they use another method to determin the octane rating so your 93 octane is probably better then our 98 octane stuff.
Guest Nismo_Freak
Dunno... probably the same? WRXs get away with 14 psi on this "93". One of our gas stations underrates their gas... its 93 octane via label but it sure smells more like race gas than pump gas. It hasnt been tested but word is these stations have around 95-97 octane instead of 93 octane. I dunno, it doesnt seem logical why they would put higher quality, and more expensive gas and sell it as 93.
Guest Nismo_Freak
Originally posted by slip
who cares what number its going to put out.  Just build it and see, you cant do any more than that, and no-one can tell you what its going to make either.
Before I go and spend 10K US ... I wanna know what it will put out, ball parked at least. Im more or less trying to figure out what the motor will output at safe boost and what safe boost is. Also general output numbers work well for tuning. If I get the car up there and make 100 hp short of what alot of other people are getting then I know there is something wrong with the motor and I need to find out what it is.
    • Every time I have to buy new tyres I question what actual difference it makes between running $40 tyres and $300 tyres and whether it's worth it. Because that's a massive difference to the wallet. But then I did go to a driving training at some point which also included emergency braking and swerving in the wet. In part I think it was meant to show people how bad it gets. Funnily enough what I took away from it is that I can go much harder than I thought in my car. I presume mostly because of decent tyres. Some of the other cars there were shocking to behold. And a bit scary that cheap tyres are probably a lot more common on the road than decent ones
    • I'm pretty sure that is just straight AI generated word soup, where did you receive that ad (facebook)? They misspell Pirelli twice, no human eyes looked at that before it was posted. Incidentally, I am running the chinese pirellis on my V37 and they are.....OK....I didn't go looking for them, they were just what the shop had in stock in the tall size that car needs. LIke any brand, you really can't trust the brand's reputation to apply to every product they produce. Pirelli make good and crap tyres, all with the same logo stamped on them, and all with an attempt at price premium due to the brand
    • Welcome.  It's unfortunate,  but a lot of these vehicles just haven't had regular and thorough maintenance for a long while. Once its back up to scratch, it should provide fun and fairly trouble free motoring.  Keep us updated with what you're doing with it.
    • Ya thankfully I've been able to drive it, it's pretty fun however I noticed yesterday while driving to work that my left side of the car is very wobbly, like any bump I go over it jolts the whole vehicle and pulls the steering wheel, I kicked the wheel a few times once I got home and it's a very distinct metal on metal clunk, so I guess I need to take a look at my suspension, maybe it's a control arm bushing or tie rod
