Item: Genuine HKS intercooler
Website:
Item Condition: Good Condition
Reason for Selling: Due to upgrade
Price and Payment Conditions: 200+postage
Extra Info: intercooler core size is 400x270x70 overall with end tanks is 530mm
Pictures: can be suppied
Item: Garrett GT30Ball Bearing Turbo 550hp
Website:
Item Condition: as new Condition
Price and Payment Conditions: 1800+postage
Extra Info: .70 front polished housing, .82 rear, t3 flange, can sell with heat bag for an extra $150, turbo has only done 500km
Contact Details: [email protected] or call 0418156085
Edited by ilum4eva
aint these turbos 1800 new? correct me if im wrong
if so id like 2 know what the new price will be? may be interested.. ;)
  • 3 weeks later...
The hks intercooler has been sold. The new price for the turbo is $1800 which now includes postage, the heat bag, a new exhaust gasket, t3 turbo gasket and the turbo of course that's more than $2500 in value for $1800. I also have forsale is a rising rate malpassi with a gauge that's only done 10hrs work. I'm asking 150 plus postage.
pls e-mail me with any further questions at
[email protected]
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
