The reason i ask this is because I got done for having neons fitted underneath my car, they were not on. But apparently it does not matter whether u turn them on or not it is illegal just to have them fitted. I've been told that it is a load of crap and some agree with the copppa. I was wondering if anoyone else actually knows for sure that they are illegal to be fitted?
https://www.sau.com.au/forums/topic/99447-undercar-neons-legal-or-not-qld/
I've heard (in WA at least) that it is legal to have them provided that you can't actually see the tube sticking out from under the car. Limos have them over here, and so do party buses. So if people/businesses like these can have them, why not cars? I've also heard of being able to obtain a permit for these, kind of like an engineers certificate or something?
"My cat's breath smells like cat food."
My uderstanding is that its illegal to have them turned on whilst on the road. The ADR's talk about couloured lights not beeing visible if they show from the front, but not about their being installed.
Edited by 4door_Sleeper
As a member of Victoria police it is my knowledge that you can have them under your car and turned on as long as they don't flash. You can't have differnt coloured lights in brakes, parkers or any other safety lighting. You can't have red lights facing forward. That's just my knowledge in Victoria but these things change about every 6 months. It annoying to drivers and police alike. I would not recommend them though as it just calls out to be pulled over and put off the road for something else though.
Yeah, just moving from victoria to nsw, the rules are different, in victoria most police say they are legal (and a few said they looked cool) but in nsw they arent. Saying that, i couldnt pass a roadworthy in victoria with them fitted, i had to take them off. So there is my 2 cents worth
in QLD, there is no law written on the use of neon lighting underneath a car...i phoned qld transport :)
however, if they are on, they can be distracting (they all will be according to law enforcers), they cannot be blue, red or even white (i think) as they are reserved for emergency vehicles
as for having them fitted and not actually on, you should be fine, get a notice from qld transport or look in the TORUM VSS (vehicle safety standards) :spank:
at work oneday we found a queensland transport documnet or something cant really remember...waht i do remember tho is that you can have green neons under your car (while your driving - i think) as long as they dont flash. red/blue/white etc are reserved for emergency vehicles...nothing uses green
Yes. They are legal in WA aslong as you can not see the tube itself.
Yep, Red and blue cannot be used, as for some reason can be mistaken for police lights. How so i have no diea. White is not alowed for some odd reason. Havent really looked into it.
I think you cant use orange aswel. Because they use orange for road sweapers, and RAC 4x4's and such.
Edited by Twitch
White (I assume) would not be allowed because it could be mistaken for reverse lights... <_<
Damn ADRs...
i read it somewhere in some document. i will try and find it.
but it was under extra lighting.
it mentioned under car lights.
said cant have white, red, blue or yellow.
and gave an example that u could have pink no problems
aghh found it.
some standards from queensland transport
this is section 3
go to page 85 and it is under additional lighting
AIS_codeofpractice_Section3_20_Feb2004.pdf
Edited by r31baboon
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
    • Ye, in terms of bolting up the "Conversion" from a GT to a GTT is effectively "Use GTT parts for everything" Except the subframe itself, because you won't want a HICAS/4WS subframe. Remember your ABS system will be different too, thanks to GT being the S15 3 sensor system, instead of the R34 4 sensor system for wheel speed. I do not know how people get this to work given R34 diffs do not have a provision for an ABS sensor (they are on the tone wheels of the axles). I assume***** people use S15 gear/R34NA forever when they realize this - Or they convert it to a rear diff/axles that are R33 style which I presume has the singular speed sensor on the diff itself, but then you have to wire it all in and...and... and...
    • Foreshadowing was never so easy.
    • The ones in brackets are the first stages of tightening. I usually aim for the middle of the range. They give a range because it's actually not that critical to hit exactly the right bolt tension. Enough is enough, and too much is too much, and the range given is inside that range. Half of the bolts in the suspension are problematic for putting a torque wrench on anyway, so just get done up to mechanic tight  and spanner checked a week later.
