I'm unsure about the N/A's but can clear up the turbo diff ratio's.
R32 GTST runs a 4.363:1 diff ratio.
R33 GTST runs a 4.11:1 diff ratio.
GTR's run the 4.11:1 diff ratio.
I would assume the N/A's will run the lower 4.363:1 diff ratio.
I was assuming after all.
Merry Xmas... ho ho ho.. :D
So the R33 N/A runs a 4.08:1 ratio.
The R200 comes in a variety of ratio's so we have plenty to choose from.
All that is required is a change of the crown and pinion.
Right from 3.7 (3.69 I think to be exact), 3.9, 4.08, 4.11, 4.363:1, 4.6 I think it was, I also do remember there was some even higher diff ratio's.
All parts are also very cheap.. Just a pitty there isn't as much of an option for the VL.
There is one option. The R31 runs a 3.7:1 and 3.9:1 ratio. Take your pic. :cheers:
Edited by Cubes
Best bet is to head over to calaisturbo.com
They know the ins and outs of which diff fits what.
I do know a friend of mine is going to fit up a 3.9 or 3.7:1 diff ratio in to his VLT open wheeler depending on availability.
He prefers the 3.7:1 but 'may' end up going the 3.9:1.
I used Pintara 4.11 crown wheel and pinion on my aussie built r31 skyline with the borg warner diff . I fitted the crown wheel to the skyline centre . It bolts straight in ( bolt holes are the same ) . The skyline has 4 side gears as against the pintaras 2 . Also skyline has 28 spline axles , pintara 25 spline axles . My diff is open centre but i have fitted a mini spool which cost me $ 77 new . I,m not sure about axles for a VL think they are 25 spline with the turbo model having 28 spline , i may be wrong .
By the way my engine is rb30de , and was happy with 3.7 gears , but i just wanted better times at the drags , hence the 4.11 mini spooled diff .
Edited by dondesoto
 Share
