Item: 19" Vault Deville Rims
Item Condition: in good condition, with slight gutter rash on two rims (not noticeable). althouth they will need new tyres very soon. (i have a friend who owns a tyre shop in syd and will give a good price on tyres)
Price and Payment Conditions: Now $1500 (was $1800)
Contact Details: Contact me on 0422 299 414 or emal me on [email protected] for any queries.
also, they come with spacers, spacer nuts, and lock nuts.
here are some pics:
thanks guys
Edited by SECUR1TY
https://www.sau.com.au/forums/topic/99470-19-vault-deville-rims/
nice ride man, wheres ya front bar?
thanks mate, its in the garage, ive got to sort out my ride height before it goes back on. it sits around 50mm off thr ground with the bar on.
could you take a pic of how much tread is left on the tires?
look at puttin these rims on my celsior
sure thing mate, ill do that tomorrow.
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
