Just wondering if you guys try to keep 1.000 as ~14.7 A/F like the manual says.
Reason I ask is because I find that the Injector map number does not always correspond to the correct A/F.
I am running 555 nismo injectors, and did the 78.5% overall injector compensation. I found this leaned me out up top, so I bumped up the Injector map numbers. Some are now maxed out at full enrichment (1.496 which should correspond to a ~9 A/F ratio, but it definitely is about 12 A/F), and I want more resolution up top so I can add even more fuel if necessary.
My question is, is it common for people to use bigger injectors and keep the OVERALL compensation at say 100%, then lower the entire Injector map so the numbers don't correspond to A/Fs anymore? I am thinking about doing this so I have more resolution in the top.
Please no "go to a dyno and get it done" posts, I want to know how its supposed to be done. If i went to a local dyno I would probably still be the one making the changes. I've got wideband, egt, and fc datalogit right now, so any suggestions would be appreciated, thanks.
Edited by gawdzilla
https://www.sau.com.au/forums/topic/99477-pfc-injector-map-tuning/
1.00 lamba is 14.7:1 afr.
1.4 is lean as f**k.
<1 is rich >1 is lean
you need to acuratly check the flow and work out the corect compensation.
i had the same problem putting 550s in place of 440s in a gtr with an autronic.
it can be adjusted mathematicly but the "responce of the injectors will be off so it will be too rich onto boost and to lean up top for example.
basicly adjust it to get the exact same afr as before the swap
Edited by T04GTR
gawdzilla,
You are right... greater than one is richer, less than one is leaner.
Unfortunately your going to need a wideband if you don't want to throw it on a dyno.
Zero out the inj correction percentages and tune the map to achieve the afr's your after. A mate of mine runs 550cc's, from memory his inj map to achieve stoich is around the 60 somethigns. 66 seems to ring a bell.
If having the inj map looking a little messy bothers you grab a datalogit and use the recalc base function after its tuned. This will set the entire map to 1.000 hence 14.7:1.
The only real problem with doing this is it also sets the moderate and high load inj. values to 1.000. Obviously these map area's are not 14.7:1.
I haven't used the recalc base function myself but do plan on doing so. From what I gather the only way to achieve a 'normal' looking afr map is to do a few little tests with pfc fuel values and the 'real' afr. Perform the adjustment calcs required on certian load points hit recalc then perform the calcs again.
Hope that makes sense.. I've had to cut it short as I am heading out. :P
T04GTR, you are talking about wideband lamdas, while i am referring to the PFC injector compensation number.
gawdzilla,
Hope that makes sense.. I've had to cut it short as I am heading out. :(
thanks for the input. thats exactly what I was asking about. your explanation makes sense to me. btw I do have a wideband that I am inputting into datalogit.
I actually just tried out my "new map" with the total compensation set at 0, and my injector map leaned down a lot to compensate for the injectors. .809 ends up being pretty close to 14.7:1 for me. i'll look into the recalc base function and see how that works out. What values are modified by the recalc base? overall injector compensation %age?
The recalc base from what I understands basically places a correction value on the base map so the values as all 1.000 on the map that is editable.
As I said in the prior post, it does cause problems with the moderate and wot areas of the map as it too sets them to 1.000.
It will require a little fiddling as I haven't fiddled with it.
You may be able to simply set the moderate and wot load areas to 1, do the recalc base then set it back to what ever, in theory if the origional value is 1 it 'shouldn't touch it when it does the recalc.
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
