I did not ask if you wankers (MCF05/slide247) thought of VLT's in general, nor what you (who the fck are you anyway) thought of the people who drive them.
I was after serious factual replies based on peoples actual experiences. Like the other guy said there is no need to slander vlt's making statements that leave people feeling dumber and irritated.
The board is not for you to come into any thread you please and put a car down because you think your car may be better than the one mentioned or you dont like the people that drive them.
Thanks to those that provided useful info, im not sure it will be getting filmed but i will post back in the future how we go.
Mick
I think it would be a very very close race but I would see the VL catch it up top due to the gear ratios and lighter weight. :D
gear ratios are the same as far as i know
5th might be shorter
final drive may be different
curious to see what wins, due to diff ratios i would say the vl will have more top speed but if you can pull a few car lenghts on it early on it might not be able to chase you down. can you please post up race results including distance, road conditions(um i mean track) and obvious different setups between cars. You would think the skyline would have more traction over the vl on the street and be able to grab enough of a lead to finish it off, but on the other hand i wouldnt underestimate the vl. ?????????? interesting.
The diff ratio of the vl cancels out the fact that the rb20det rev's higher.
Check out this dyno comparison from a recent dyno day, all done in 4th gear.
Natho has a VLT RB30ET with only a 2.5" exhaust, 13-14psi on the stock turbo, and small AVO fmic. He made 187rwkw. Pretty damn good effort.
Chris32 runs a 3.5" exhaust, PFC, HKS 2510 & FMIC.
Ronin runs an Rb20DET, exhaust, fmic, rb25 turbo at 14psi and a remapped ecu. 190rwkw.
Oosh runs a fairly stock R32, from memory only an exhaust and a little boost.
As you can see the R32's do have the edge with regards to top end and they also have roughly the same bottom end torque at the rear wheels low in the rpm due to the R32's running a 4.363:1 diff ratio.
Then there's my RB30DET that hardly rev's due to the stock log manifold, stock cams and small turbo.
Conclusion... I still think the VLT will have the edge due to having less lag and a little more mid range even though the diff ratio is working against it. It also has the advantage of the solid rear axle that holds all of the tyre on the road unlike the IRS that squats and runs on the inside of the tyre. Providing the skyline has its camber setup well without stiff suspension it should be ok.
BUT.. come highspeed, who knows. I don't know the drag coefficient of the R32's nor do I know them for the VLT's.
Aero dynamics will be the determining factor.
None the less it will be very close providing the R32 owner can drive decently and get past the lag without bogging it down or turning the tyres to smoke when launching. If the VLT gets the jump you won't be catching it. Chances are it will get the jump due to its solid axle that holds the tyres flat on the road not to forget it won't require as many rev's to get off the line as the turbo will spool quicker than the rb20det.
Many VLT owners have dropped well matched T3/4's or BB turbo's on their VLT's and experienced no lag difference to the stock bush turbo. The stock turbo does lag a little compared to whats around these days.
as i always say.... just race. i raced my mates v8 5litre (statesmen) with a claimed 192kw... he bet my by a car length.....
considering my car is a sr20de front wheel drive auto...
he won... but was dissapointed coz i was right behind him. i belive if i was manual it would be neck and neck or i would beat him. only reason he won was because he took off from the word go and i caught up to him after first....
PS "winnings winning, wether its by an inch or a mile"
but your also looking at double over head cams and all that sought of stuff too no wouldnt that equal some things out to the rb30?
i would have thought the 32 would beat it, but i dont know enought about them.
In the end take the cars on a race track and you will know the 32 is a race car not a go straight car.
Edited by koleka
r32 should hook up heaps better than the vl - especially if vl has no lsd.
Having owned commos and raced them in skylines/silvias commos just are crap off the line UNLESS you do work to the suspension.
Rolling? Depends on how quick you're going - I can just beat a r33 gtr @ 20km/hr rollon in first gear but still am getting crazy wheelspin.
The commodore will lose I'd say at a 20 kay roll on - it'll still just spin.
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
