any one know what a brand new air flow meter is worth for a r33 gts-t at all. my sons r33 was running like crap so we cleaned the afr for very little difference .so then we took the afm off my r33 and bolted it onto his car and farken hell what a difference it made so much smoother and goes like a cat with deep heat on its nuts plus his car has been using so much fuel its not funny so im hoping the afm was the cause of that as well . really dont want to put a second hand one back on his car just in case it is half buggered as well but have no idea what a new one is worth ? anyone know and would you have to buy a geniune one from nissan or can you get after market ones?
cheers midlife crisis
https://www.sau.com.au/forums/topic/99495-afm/
I recently had the same problem mate. My afm was screwed when I bought the car. I got it reconditioned for $350. Took a while for them to get the specs right but when they did it really cracked. I have heard new afm's costing from about $700-$950 brand new! If you can try and find a decent second hand one or get it reconditioned like mine. New ones are pretty rare and expensive.
https://www.sau.com.au/forums/topic/99495-afm/#findComment-1813754
gee i didnt think they would be that expensive might have to go the secong hand way . as for the ecu its just standed car just has a cat back exaust and a pod filter . he is not really chasing power as it goes pretty hard as it is just wants it to run clean , lol i dont hold much hope of getting my afm back of him now :-(
regards midlife crisis
https://www.sau.com.au/forums/topic/99495-afm/#findComment-1813950
If you can use a soldering iron why don't you have a go at repairing your old one?
I did mine a couple of weeks ago and it transformed the car.
No more black smoke, it no longer stalls or hiccups and I get another 100km a tank.
You just cut through the outside edge of the sealant around the cover panel and carefully pry it off.
Unsolder the metal shield on top of the circuit board.
It's best to remove the solder with some desoldering wick.
The problem with mine was where the socket pins are soldered to the circuit board the solder had cracked.
Probably from someone wriggling the plug to remove it.
Just heat where the pins cross with the tip of an iron to melt the solder and add a bit or fresh resin-cored solder to each joint.
I also did a blanket resolder of the whole board, while I had it apart, just to be sure there were no dry joints but I think it would have been ok if I hadn't.
Resolder the shield and reseal the cover with sikaflex or silicon and your done.
https://www.sau.com.au/forums/topic/99495-afm/#findComment-1814266
Cheap second hand SAFC will do the trick, scale the voltage back to the origional afm values.
Definitely worth while if you need an afm now and have plans to throw a safc on it anyway.
Think of it as for the price of a new std item from nissan you can have your self a bosch z32 + safc, making more power and slightly better fuel economy.
Edited by Cubes
https://www.sau.com.au/forums/topic/99495-afm/#findComment-1815762
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
