Ethanol effects
RAA on Ethanol
Nissan Statement
So - assuming Extreme doesn't go off like the 'old' fuel did, it should be fine. And the stock computers have two fuel maps, and the high octane map is supposedly for 100 Octane.
Edited by mjfawke
Thats a nissan Australia statement, not a nissan Japan statement. im guessing the majority of us would be using cars from over the big blue....
Last time I checked, Nissan Australia imported all their cars prebuilt from Japan, they werent made here in Australia :(
stopped in at Phillip tonight and saw Ultimate was back *yay*
so much for them sending an SMS when it was available :)
and to anyone using Vortex 98 from the Caltex at Braddon I wouldnt do it...someone I know with a high powered turbo car has been using it....his fuel pump stopped working and his mechanic said its the worst looking filter he has ever pulled out of a tank of a 15 month old car.
it might be ok at other servos...but anyway..
Ultimate's been back at Phillip since Monday or Tuesday I think, or wherever it was I filled up last
I'm quite pleased with how my car went with Synergy 8000, it actually seemed to give my car a bit better mileage than the Ultimate did.
After the stock computer has done its post-reset timing thing, I've never been able to tell the difference (performance wise) between Optimax, Ultimate, and stock 95 premium (Mobil). With the hi-octane fuels, the everyday initial performance after the motor has first warmed up is better, but after giving it a hard time they have all been pretty much the same.
However - I loaded up with Optimax Extreme last week, and the car's a farking rocket all of the time now... So I guess I have been dropping down to the low-octane fuel map most of the time. I think I will reset the computer again to see how that goes as well!
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
