  • Replies 425
Posted Images
Hopefully my car will be ready for this cruise... If not, it's just coming in its current state, I'll bolt everything on after :cheers:
As one of the cruise whores on this forum (for NSW) I say at the meet, we do a ROLECALL :) that way we know who's dogged it :(
Seriously, Steve has put heaps into this one... only say yes if you are definitely coming! It's not fair to him and its definitely not fair to his wallet!
I'll definitely be there... arranged for a day off and all
I dont have you on the list - r u going?
Yeah, count me in...!
My 1st ever Sydney SAU cruise... I'll be representing WA... Hahaaa! :lol:
Anyone heading out from City area? If you are, could meet up somewhere nearby and head to Homebush together...
Out of interest Steve, does the destination point have enough parking for 50+ cars ??
Yeah the spot i checked out has heaps of parking (i even went on a sunday to make sure it doesnt get crammed full of beachgoers)
We shouldnt have a problem with parking
In the rare case that we do have a problem fitting so many skylines in - the bbq and all the food is portable (obviously) so we can keep going until we find a more suitable spot - and there are heaps of car parks down that road
Hopefully my car will be ready for this cruise... If not, it's just coming in its current state, I'll bolt everything on after :)
As one of the cruise whores on this forum (for NSW) I say at the meet, we do a ROLECALL :)  that way we know who's dogged it ;)
Rollcall - as corny as it is, its the only way for me to know whos paid for lunch, so, as much as i DON'T want to do it ......
Yeah last min pikers will really give me the sh!ts - it should be a good day, and could become one of the regular SAU cruises
My wallet says thanks :P
what if i want to bring some of my mate and there car along as well would that be cool?.
Easy - tell me how many to add and ill put them next to your name
Tell them its $5 each for lunch
Done deal :)
u need an extra bbq.that is allot of saussages.--->>can any1 supply an extra bbq<<---
How many saussages do we get each?what about drinks?
Much of heinz's finest will be consumed that day or the cheaper stuff which i personally would opt for.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
