i am sunburnt... :)
me too!!!
Was a top day, I'll keep my schumacher (sp?) antics to myself next time ay scotty!?
And Links... where the hell did you go to on the way home? towards maroubra? I thought hell, I'm not getting lost again, then took off towards the ED and went through the cross.. ran into the WA boy on the way home (but no wave! grrr!)
  • Replies 425
Posted Images
Hey guys n gals,
Great day. Well done to the organisers. :)
Thanks to the kind soul who gave up the sunscreen to the "little woman" at the destination, it is a pity she didn't use it on her face that is just getting redder by the minute. :wavey:
Was well worth the trip from Nowra to Homebush to see that carpark full of beautiful cars (mostly Nissans) and to cruise with you all. :P
Looking forward to the next meet-up. :D
El Bee & Humbla (Genelle, or Pink Lady)
yeah.. that.. well.. as I left the lights.. didn't realise it split until it was too late.. we went through to redfern than over the bridge.. sorry about that.. wasn't looking where I was going..
was a good run home..
To all the organisers.. well done.. went off without a hitch!.. cheers for all the food.. hope everyone enjoyed themselves..
Awesome day guys... well done to Steve n co. for putting it all together! As mentioned, event went down without a glitch and everyone was well behaved :D Top work!
If only my car didn't screw up just before we left Homebush, the drive would've been a lot more fun! Goes to show you should never reassemble a car at 3am in the morning :)
BTW; thanks goes to Craved, Mintie, ECL, and Links for the technical support and tools once we arrived (drive home was so much better :P).
my head looks like a tomato, lol.
Thanks for the great cruise guys, well organised and heaps of fun
Drive home was great as well.
hahah was alright.. where did you pop out from?
driving all that way offboost was not that great for me :P
great day, and was good to have all the catch up meets along the way..
Great day, big thumbs up for the organisers !!!
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
