this is my new skyline. its a 1981 hgc211 gt-ex. have fitted a close ratio dog box 5sp, rs legacy water to air intercooler and remove all the emission gear. it runs a locked diff. have taken it out to the track for a few drift days. went ok but needs decent clutch and fimer suspension. want ot upgrade to a l28et.
Edited by hgc211 turbo
https://www.sau.com.au/forums/topic/99643-my-new-skyline/
Interesting, a nice looking c211 you have there. Its obviously an import, i would hazard to guess that you have the only c211 gt-ex turbo in Australia. How much did it set you back? Have you tuned the motor aside from the intercooler?
$200. im in nz. some old guy was trying to sell it to a wrecker!!
https://www.sau.com.au/forums/topic/99643-my-new-skyline/#findComment-1815914
holy shit dont see to many of those here, cool engine too
dont crash it, please
did you bring it in or did you buy it off someone else who  imported it?
im from nz i payed $200 for it !!!
https://www.sau.com.au/forums/topic/99643-my-new-skyline/#findComment-1815916
that i/c is interesting...easy to do?
pretty easy, had to make a adaptor plate for the new trottle body and had to moun i/c water pump and radiator. made a big difference but not enough, have taken all the emission gear off it .
https://www.sau.com.au/forums/topic/99643-my-new-skyline/#findComment-1815920
I've been sort of considering using one of them on my DR, by big difference what do you mean? reckon it's worth it form a budgetry point of view?
Thanks.
Rob
https://www.sau.com.au/forums/topic/99643-my-new-skyline/#findComment-1819240
well it made a difference buy being able to wind up the boost and to stop pinking, although it depends on where you set the timing to. mines about 23 degrees. i forgot to mention i had replaced the turbo with a r31 rb20det turbo and i have been running avgas in it to. im running about 13-15 psi boost.
https://www.sau.com.au/forums/topic/99643-my-new-skyline/#findComment-1819734
thats why i did it, i needed to get some more poke and didnt want to spend a cent, but i got sick of the intercooler pump noise pretty dam quickly. must be stuffed. probably not really worth it in the long run really. will be fitting a front mount intercooler soon dont want it tolook to wanky tho!!
https://www.sau.com.au/forums/topic/99643-my-new-skyline/#findComment-1819742
    • If you are fine with China turbos, Maxpeedingrods makes a bolt on turbo. Ive had mine for two summers now and it seems to be holding up ok.
    • Howdy all Im in a little predicament and wondering what everyone’s thoughts are? I’ve had my long block rebuilt and am in the market for a turbo due to my old one having metal shavings from crank bearings (cause of rebuild) go throughout the turbos oil lines and there wheel has a little play. I’m not really aiming for any power, just trying to keep it as oem as possible, but I can’t find a turbo that’s built for the stock ecu or find something that would be a standard replacement. Anyone have any ideas or suggestions
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
