DASH - DVD Player with In-built 7' touch screen tv ($2200)
- Sony head unit (imported) motorised dual face flip screen($1500)
SPEAKERS - all boston acoustics, cant remember the exacts, but they cost me $1800 all up
BOOT------------------
SUBS - 2 x 15' Fusion Lomus ($2000)
- 1 x single flow, dual slot port box (made myself)
AMPS - 2 x JL Audio kilowatt amps (subs) (over 2gs i think)
- 2 x boss 160 watt amps (fronts) (sfa)
- 1 x (grr forgot brand) 400 watt (rears) (also sfa)
i would like to say thats what is in my car, but its not... yet...
the dash stuff i have and is probably going in this weekend, if its not raining...
3 of the amps i have, the box design is finally finished and peachy, so once i get some money together, im gunna make that, then buy the amps, then install, then buy the subs (i have other shit subs to take the place for the mean time)...
will post pics of the install and what not when i have the $$$... and probably of the car too, when i take some photos... :(
HU: Alpine CDA-9831 (50Wx4 output) ($500 discouted from $800)
FSP: MB Quart DSE-216 (6" Splits) ($300)
RSP: Pioneer TS-A6955 (6x9) ($150 years ago)
AMP: Alpine MRD-M500 (500WRMSx1) ($700)
AMP: Alpine MRV-F340 (55WRMSx4) ($600 discounted from $800)
SUB: Rockford Fosgate RFD-2212 (1000WRMS) ($500 discounted from $700)
Overall: I love every part of my setup, the deck does everything I need and the MB Quart splits are sublimely perfect. The only thing I would change is my rear 6x9's to some 4" 3-way's, but I can live with it coz I'm in the front not the back. I have had my amps and sub for nearly 4 years now and never had a problem. I ran all new Aeropro cables myself to do away with the crappy factory cables. I had a 500CCA Optima in my TX3 but it doesn't fit in the R32 GTR battery spot :D
All my parts have come from Alberts Car Stereo and I would recommend them highly.
--Tom
Headunit: JVC xx7000(?) - $650 -- 8.5/10
Front: 6.5" Alpine 'R' Series Splits (w/ 1" tweeters) - 9/10
Rear: Pioneer (Cazzoiera) 6.5" Splits (Decent quality tho) - 7/10
Amps: Clarion 4 x 100WRMS -- 7/10
MTX Thunder TA8502 (1 x 750WRMS @ 2Ohm) -- 10/10
Subs: 2 x Cadence 12" 800w -- 10/10 (6th Order Bandpass Enclosure - 3 cu ft)
These subs are AWESOME for the price (approx $130 each).. they are US made, and have taken tonnes of punishment from the MTX amp, and they crank in a decent enclosure!! Can definitely recommend.
    • If I had "perfect R33 GTR" kinda money I would have bought one of the crazy expensive low mileage HJA cars, but I am sadly not that wealthy. I already picked this car out of various Skylines for sale locally, most of which were worse in some way. Only a few cars were actually better but also more expensive. In terms of buying a motor locally, I at least have the option to inspect it myself and juding the seller as a person, and used or freshly rebuilt engines that some people sell are actually ok price-wise. I knew the car was going to require work, but shit piled up real fast and I haven't even driven 1000km yet as the turbo started oiling like a bitch within a few weeks after I got the car.   I assume it wasn't actually me who cracked it, though there is no way to know when that crack formed and if the previous owner even knew it was there. Buying another 05U Block can be a gamble, yeah, but the cheapest PRP cast block is like twice or more money-wise, and billet is 3 or 3 times as much. For now I am most likely just keeping the current engine, as a rebuild or engine swap isn't happening right now. But I am seriously considering buying a second engine and selling mine in return. Might be a sweet deal at the end.
    • Hi all. I need some help buying the correct size banjo bolts for my 2860 turbos. Because whoever installed them tore up the original part, I ordered new ones of this kind, because I just figured these were the most leak-resistant option as I already had trouble with a shitty braided line. I need to know the thread size of the smaller left hole, that is the turbo oil feed connection. I found out so far that the turbo oil inlet apparently has a 7/16"-24 thread, but I cannot find any listing or description of the thread size on this line. I do not have the original bolts. I tried using the bolts that were in the turbos (the ones that were mounted with the shitty braided line) but they sit very loosely so they can't be the right thread. Means either these bolts are the wrong ones (how do they fit the turbo then? no clue) or the wraparound-lines have a different thread than the turbo oil feed itself. Help is appreciated, asking Nissan directly is obviously not going to work.
    • EDIT: PSA to whoever stumbles upon this thread. It is in fact a crack in the block that caused this concern. Just letting you know. In my case, a few cm long hairline crack going horizontally above the turbo oil feed. Classic RB shit I guess
    • Might as well pop in some cams, head gasket, head studs, and a flex sensor. Full send.
