heres a dyno graph all readings are on the same dyno (different days though) and they are on the same graph to read easier.
they are all rb26 engines with rebuild bottom ends (except the highflowed turbos engine which is dead stock). they are all stock capacity and the t04z engine and gt42 engine have different cams to stock.
there is a...
GT42 with 1.0 housing
garret T04Z 0.84 housing
r34 ball bearing low mounts
r32 highflowed stock turbos
here ya go...
cheers
Brad
https://www.sau.com.au/forums/topic/99705-turbo-comparisions-on-rb26s/
If all of the turbo's were tuned to max power then psi is irrelevant, one may make less power with more boost.
Diff ratio's here are irrelevant as its all done to RPM..
The poor bloke with the GT42.. Much too big for the 2.6ltr.
Excellent comparision.
Edited by Cubes
Fair enough, I missed the point that they were all rebuilt and tuned to max power.
Only saying that - some engines/boost may not be tuned as high due to different compression ratios, based on HG thickness or engine comp ...
But this is probably the best comparo possible. But i would still like to know boost pressures run across the board, if at all possible
the gt42 was lowish boost, i think around 20psi from memory, the t04z is on 18psi, and the r34 bb turbos i dont know, and the highflows are 18psi.
the t04z graph is simon (r32 GTS) on this forum on low boost (made 620hp i think recently on 23psi)
or by this you can see that twin hks t04z with 0.63 a/r rear housings are almost as responsive as a gt42 with 1.06 a/r.
added a garret t04z with.8 a/r as well for comparison
gt42 is running only 20psi
t04z are about 24psi
twin t04z's are about 28psi
Edited by Cerbera
Funny how some shops will claim more power from one ECU to another.
All ECUs will make the same power if the timing,fuel,turbos,intake etc are the same.
Note that its also the only graph not in full shootout mode.
The history of the 581hp car makes it a poor example as its had a few GCG turbos and GT42 cartrage in GCG housings and many engine builds plus 3 different ECUs and a best of low 12s at the drags, tho the Wolf that it was lending has done the fastest GTR pass in WA to date at 10.7.
Still looks like the TO4Z is the best street strip turbo at the moment.
LOL fastest GTR pass in WA @ 11.7
are you on crack
ND4SPD 10.7
Simons GTR 10.8
Got Boost (gts4 with rb26) 10.9
not even close to the lofty 11.7 you speak of
f**k even bobbos dead stock GTR did 11.8 .. stock turbos internals cams, mines rom, boost zorst and it hoses many a aftermarket ecu equipped GTR time..
Yeah the 581 rwhp is such a crap example.. had massive money thrown at it, blown up on a dyno (oh the memories) , its not like the dog box, autronics etc etc meant that the owner built the car to the best of standards...
/rant over
Brad well done for the post
Edited by [teejay]
The history of the 581hp car makes it a poor example as its had a few GCG turbos and GT42 cartrage in GCG housings and many engine builds plus 3 different ECUs and a best of low 12s at the drags, tho the Wolf that it was lending has done the fastest GTR pass in WA to date at 11.7.
also i do believe 2 GTR's and one GTS-4 have done 10's in WA
Edited by Cerbera
Actually, the fastest pass by a gt-r in wa is Kier wilson, 9.something in his drag gt-r, and his street car backed it up with a low 10, and they both run motec..
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
