Had my Skyline for 6yrs and have only been pulled over once, as i went through a booze bus.  Had the fmic, exhaust, and 19's for at least 4yrs, so the car never really looked stock.
It's all about how you drive, if you are an idiot on the road then they will always pull you over.  Once you have a bad rep. with the police the hassles never stop.  So keep driving like a fool and enjoy the harrasment, just don't cry like a biatch when they defect you 3 times in one month.  :lol:
fair enough, but some of us do get harassed for driving a "performance"
example- dropping a female friend of at a club sat nite resulted in being pulled over 3 times in 1hr,
1st policeman -breath test, licence,ok drive off, good guy polite etc
2nd policeman- breath test, check rear tires, check out the girl, ok drive off
3rd policeman-treatens to take my car of me, sees me doing a burn out, no wait heard the tires screech, or sees smoke, this wanker is pullind shit out of his arse, after debating with him for 15mins that i simply drove through a round about(and slowly) he gives me a fine for undue and exesive noise,($100 fine)even though i show him permits for my exhaust???
he simply wanted to target me
he goes on to tell me if i want to "hoon" go out of the city a do want you want
so i have been told by a policeman to go do burnouts
so al it is not how you drive its unbiased harrasment from cops with a night stick up there somewhere and i am sick of it
If this is really your opinion then stop having a cry saying "SAU does not drive illegally, etc. If someone wants to drive like an idiot and get hassled by police let them. SAU has no right to tell people how to drive unless they have a SAU sticker and are a SAU member. Then it reflects on the club. But just coz someone drives a skyline doesnt mean they have to drive like a grandma.
Exactly, even with the stickers i do not tell people how to drive. But don't come on this site and glorify your actions. What do ppl want to here; "that was fully hectik bro, last night i too done 2 doughies and fishied up the street". We all have cars capable of doing such actions, but who cares, we've seen/heard/done it ALL b4.
What most young guys don't consider is: what if the unexpected happens?
Such activites are best done in a controlled location. You only have to look at my sigs and you'll see i'm no granny when it comes to having fun in the 'line, but on the road a bit of respect for other ppl's safety must be shown.
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
    • Sounds good. Provided the panel is flat/level I'd be happy to start the painting process.  While you are learning, for sure you could do this. Its only paint, you can always sand it all back and start again. Its only your time and money on materials, but while you're learning, really its time and money spent on your education.  Once you know how to do this bodywork and painting, you won't want to waste your time and money on frivolous activities lol.
    • Yep I will use a guide coat after putting filler, I will do it on the whole panel as I'm a beginner so chances I've made quite a few errors. In that photo, I think that was a low spot, I just for example said to pretend it's flat but I will put filler + guide coat after to assess where I'm at. Yep with that picture, the panel is wet as it rained when I took the photo. But all those scratches are completely smooth, I went over it with 240 grit and can't feel it, even with my nail digging into it. I was legit thinking to buy a 2k can and spray primer to see how it turns out but then thought to myself it's going to be a mess doing it haha. Good mention there. Thanks for all that info I think I know what to do next.
    • Prior to laying down the primer, you need to make sure the surface is completely level. For example, based on this picture, I strongly suspect that the areas marked in blue are higher then the area marked in green.  If you spray primer over this entire area, then paint and clear it, the finished result will 100% show the low area. It will stick out like dogs balls. Unfortunately the paint won't magically level out the low areas as you lay it down.  Without seeing it in person, I expect that the green area will need to be filled, then use a guide coat and check that the entire repair area is level with a large sanding block.  With this picture, are you saying that even though you can see the scratches, the panel is in fact completely smooth and flat? If this is the case sure you could prep and paint it as it is.     The picture with the paint you described as blistering, it's hard for me to comment on from the photo alone. It looks like the panel is wet? Dunno, looks strange. Does the panel feel as smooth as glass when you run your hand over it? **** Going back to your question again, generally you would only sand the primer if you made a mistake while laying down the primer.  If the panel is prepped properly and you lay the primer down properly, you should not need to sand the primer.  This wouldn't work - Don't prep the panel. Spray primer and see how it turns out. Sand the areas where the issues appear. Spray more primer and see how it turns out. Sand the areas....... Yeah you'd go round and round in circles getting no where.
