I wouldn't want it going much past 100-110degree's.
95degree's is fairly warm, Bl4ck32 has an oil temp guage it sits pretty much level with water temp, being ~83-85degree's.
One difference between yours and his is the lack of piston oil squirters, having piston oil squirters removes heat from the piston, possibly why yours is a little higher.
Which oil temp guage did u get? one with a elec sender? How much I need one. :D
Edited by Cubes
https://www.sau.com.au/forums/topic/99711-oil-temp-warning/#findComment-1816126
thanks Cubes, i think ill set it at 105C.
all up the whole setup cost more than i wanted to spend i bought each part in stages.
Blitz DCII electronic Temp guage $200
Blitz Live-Unit II $135
Blitz Sandwich plate (goes between oil filter & block) $100
https://www.sau.com.au/forums/topic/99711-oil-temp-warning/#findComment-1816140
I've done 1,000km in the past 3 days (all 30-35c days with plenty of humidity) and my oil hasn't gone above 90c (according to the factory oil gauge in my r32 gtr, which being 11yrs old im not sure how accurate it is). That's with air intake temps of 50-55c and water temps of 76-85c.
I've certainly done plenty of hard driving (altho only at 11psi) and heaps of freeway driving.
https://www.sau.com.au/forums/topic/99711-oil-temp-warning/#findComment-1816563
Ive got a Series 1 GTS-t putting out around 270kw and the Water Temperature reading on the Power FC never goes above 81* except during a 3 lap Supersprint when it goes to around 98* and cools down to 81* within 4 mins of driving slowly. I have a Electronic Omori Oil Temp Guage fitted and an Oil Cooler and the Oil Temp never gets above 70* except during a 3 lap Supersprint when it gets to around 100* and it cools back to 70* within the 4 minuite cooldown as well. This was with the Standard Radiator which I replaced with a PWR thicker one and no differece has been noticed. Also running tank water with Water Wetter in the system.
I think 98* normal running seems too hot and I would get the cooling system flushed.
Ian
https://www.sau.com.au/forums/topic/99711-oil-temp-warning/#findComment-1816741
If your hitting 110+ degree oil temps on the street then you should look at fitting an oil cooler, no if's no buts.
Apparently at 115degree's the high oil temps begin to break down the petroleum oils and cause oxidation, which in turn forms deposits, varnish and increases wear.
Edited by Cubes
https://www.sau.com.au/forums/topic/99711-oil-temp-warning/#findComment-1816768
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
