Hey people, could someone please post how to flush the coolant from my rb25det, and what type of coolant to replace it with, its been about 2 years since ive done .
this.
r33 coupe 25t
thanks
Hey nsta. There's a bolt on one side of the radiator right on the bottom underneath. undo this to let the coolant out. I went to Nissan and asked for coolant. When it's full again bleed the system out by undoing a small bolt which is the highest point on the engine so there's no air in the system. (It's near the fuel rail) be carefull as mine was stubbourne to undo. Just spray with wd40,rp7 etc and let sit for a couple of minutes and gently undo. Hope this helps....
https://www.sau.com.au/forums/topic/99720-flushing-coolant/#findComment-1826715
Also it's a good idea to add 1.5-2L of coolant and let it sit for a couple of minutes then add again in stages til full. With the motor being hot you don't wanna risk cracking the head or radiator with cold coolant.
Edited by Topkart R33
https://www.sau.com.au/forums/topic/99720-flushing-coolant/#findComment-1827722
thanks, though when i mix the coolant with water, does the water have to be distilled, or just tap water????
and is it best to mix the water and coolant at the same time into like a carton?or add coolant, then water?
Buy some premixed coolant in bottles....about 8 L to be safe. I used 90+ at 33% coolant ratio. If you do want to mix you definately need distilled water. Stops corrosian on alloys, but the easiest way is premixed.
https://www.sau.com.au/forums/topic/99720-flushing-coolant/#findComment-1828604
  • 1 month later...
nsta: As stated up the top of this forum, This is *NOT* the place to ask questions or to try and get help.
There is no need to create two threads in differnt forums asking the same question. All you are doing is effectively making it hard to find all the answers from everyone.
As has been said before to you, please make the effort to search for the info you're looking for, because the majority of questions you ask have been asked before, several times.
I just did a quick search and found the following threads about flushing your coolant:
http://www.skylinesaustralia.com/forums/in...showtopic=96319
http://www.skylinesaustralia.com/forums/in...showtopic=69726
http://www.skylinesaustralia.com/forums/in...showtopic=62427
http://www.skylinesaustralia.com/forums/in...showtopic=53159
http://www.skylinesaustralia.com/forums/in...showtopic=12332
These two are for RB20 and RB26 but should give you some good advice
http://www.skylinesaustralia.com/forums/in...showtopic=43402
http://www.skylinesaustralia.com/forums/in...showtopic=67730
and this thread mention what sort of coolants to use
http://www.skylinesaustralia.com/forums/in...showtopic=27793
Vijay
https://www.sau.com.au/forums/topic/99720-flushing-coolant/#findComment-1941037
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
