Hey everyone,
Basically interested in importing an R34 GTR RB26 engine from Japan.
I've already got an FOB price on it in yen, was wondering if i'd have to pay any customs/duty on its arrival?
Also, I assume there's a way to keep these taxes at a minimum? :D
I'm probably going to buy it this week sometime as i need it in a hurry!
Thanks.
Edited by IOWNU
https://www.sau.com.au/forums/topic/99723-importing-an-engine-from-japan/
Hey everyone,
Thanks.
Hey, how ur doing? Im just new to this club and can u plz tell me how to create a new poll or a new quote or just basically a new forum chat?
Thanks
That is SOOOOO Off topic but anyways...
Select a forum, then click on the newtopic option to make a new thread. Once you're making the new thread, you can add a poll, pretty straight forward.
Looks like you've worked out how to quote.
yes you will have to pay import duty, and GST on it, and the cost of freight.
so engine cost + FOB charge + freight. call that cost A
cost A + %10 (duty) = cost B
cost B + %10 (GST) = landed cost
add to this the cost of having a customs agent handle the customs clearance and payment of taxes. the charge (at a guess) would be around $50-$100.
There is no legal way to minimise the tax, they will need a proper invoice and may even request the wire transfer receipt.
Beer baron is correct but you dont pay import duty on the freight cost from the jap docks to here , you only pay import duty on the jap land freight cost but you pay gst on the lot .
Just like he said no legal way to reduce the tax and if you do cheat and get cought you may loose the goods and be charged with criminal a offence , not worth it to save a few $ .
Ali, Can I ask how you went about finding the engine? And if you have, how you organised/organising freight?
Hey mate,
My Uncle lives in Japan so I often get cars etc.
Firstly i purchased the engine for about 260,000 YEN FOB. That was an R34 RB26 engine with 68,000 kms on it......bargain if you ask me.
First time getting an engine so not sure as to the freight procedure yet...hopefully find out today or tommorow.
I'll update this thread when I have further info.
Peace.
Ali
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
