I dont think he said he wanted to get 200kw, just wants to know if he can run the 3 mods on a stock ecu id be interested to know also as im interested in a smilar set up.
Edited by R33_Series2Lover
At this present time yeh im pretty much wondering if it is ok to run the exhaust,fmic and panel filter comfortably and safetly most importantly on the factory computer alone . Good to see im not the only one :P
Here's my input: I think you and R33_Series2lover are the same person. Are you? You have the same car, ask the same questions, and write in the same style. :huh:
i wouldnt even worry about the front mount. When I had my r33 all i had was full exhaust/ cat, safc and 11psi.
And there were no problems at all. In my opinion youd be wasting your money buying one if your not going to go crazy with mods.
yer, if u arnet going to fiddle with the boost (i dont know why you wouldnt though) dont waste your money on a fmic as they arent needed
turning up the boost doesnt hurt anything though, and gets you better gains than most other mods, so im unsure why you are so against doing this
even with the standard ecu, it can handle extra boost
Ahhh no im not pretending to be someone else. I give you points for creative thought and actually spending the time to work something like that out. Impressive............ anywayssssss yeh well fmic would be for looks mostly as they look awesome. I dont take my car out to race tracks or the drag strip so yeh i have a good idea of how i want my car to look like and perform and this set up would do nicely.
In theory a bit more boost should make it to the engine with the aftermarket core?? I remember reading that the stock cooler looses around 3 psi across the core so if the after market one looses only 1 psi does this mean effectively you have upped the boost by 2psi as more is making it past the core?? Not sure on this and was wanting to know if this logic rings true :)
To put it as simple as i can.
It sounds like your mechanic is switched on and you should be able to trust what he says.
Everything he has said so far makes perfect common sense in modifying your R33.
I like that he has recommended a high flow panel filter rather then a crappy pod filter, and also the point that he makes about aftermarket BOV stuffing up the air flow meter signal is also correct.
Listen to your mechanic, have a read around these forums and you will not go wrong.
I'm with RB30... your mechanic sounds like a sensible and safe guy to listen to.
I have a series 2 R33 also, and i've got a K&N filter in the airbox.
I didn't want to start hacking front bars or anything like that, so I have bought an R34GTT cooler (plenty for sale on SAU). I'm yet to fit it, but they do flow better, are a little thicker, and have bigger inlet/outlets on the end-tanks. ARC make a SMIC (stock mount) intercooler which is made from aluminium, and is supposed to be several kilo's lighter than the original. The stock R34's make 206kw... so I figure that its intercooler is good for at least that much.
My next move after fitting that cooler is to get a CESRacing split dump pipe, then source an 80mm cat, and order an exhaust.
I'm quite tempted to dyno my car before and after to show the differences using a panel filter, R34 cooler, 3" exhaust... but it costs more money! =-[
Edited by RANDY
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
    • Is MAF load really that bad? I'm not trying to do big power, my only real desire is VCAM and flex fuel support so I'm not terrified of blowing my engine apart from CA's appalling 95 RON "premium" fuel. Stuff like playing with closed loop boost control and really dialing in my transient fueling and ignition are frankly just to prove to myself I remembered something from uni.
    • Thats what ive been doing. Ive got a million questions but i know theyve probably all been answered before at some stage. Todays research included nismo heritage seat covers, s3 projector headlight retrofits and how to remove/paint the rocker covers
