I dont think he said he wanted to get 200kw, just wants to know if he can run the 3 mods on a stock ecu id be interested to know also as im interested in a smilar set up.
Edited by R33_Series2Lover
At this present time yeh im pretty much wondering if it is ok to run the exhaust,fmic and panel filter comfortably and safetly most importantly on the factory computer alone . Good to see im not the only one :P
Here's my input: I think you and R33_Series2lover are the same person. Are you? You have the same car, ask the same questions, and write in the same style. :huh:
i wouldnt even worry about the front mount. When I had my r33 all i had was full exhaust/ cat, safc and 11psi.
And there were no problems at all. In my opinion youd be wasting your money buying one if your not going to go crazy with mods.
yer, if u arnet going to fiddle with the boost (i dont know why you wouldnt though) dont waste your money on a fmic as they arent needed
turning up the boost doesnt hurt anything though, and gets you better gains than most other mods, so im unsure why you are so against doing this
even with the standard ecu, it can handle extra boost
Ahhh no im not pretending to be someone else. I give you points for creative thought and actually spending the time to work something like that out. Impressive............ anywayssssss yeh well fmic would be for looks mostly as they look awesome. I dont take my car out to race tracks or the drag strip so yeh i have a good idea of how i want my car to look like and perform and this set up would do nicely.
In theory a bit more boost should make it to the engine with the aftermarket core?? I remember reading that the stock cooler looses around 3 psi across the core so if the after market one looses only 1 psi does this mean effectively you have upped the boost by 2psi as more is making it past the core?? Not sure on this and was wanting to know if this logic rings true :)
To put it as simple as i can.
It sounds like your mechanic is switched on and you should be able to trust what he says.
Everything he has said so far makes perfect common sense in modifying your R33.
I like that he has recommended a high flow panel filter rather then a crappy pod filter, and also the point that he makes about aftermarket BOV stuffing up the air flow meter signal is also correct.
Listen to your mechanic, have a read around these forums and you will not go wrong.
I'm with RB30... your mechanic sounds like a sensible and safe guy to listen to.
I have a series 2 R33 also, and i've got a K&N filter in the airbox.
I didn't want to start hacking front bars or anything like that, so I have bought an R34GTT cooler (plenty for sale on SAU). I'm yet to fit it, but they do flow better, are a little thicker, and have bigger inlet/outlets on the end-tanks. ARC make a SMIC (stock mount) intercooler which is made from aluminium, and is supposed to be several kilo's lighter than the original. The stock R34's make 206kw... so I figure that its intercooler is good for at least that much.
My next move after fitting that cooler is to get a CESRacing split dump pipe, then source an 80mm cat, and order an exhaust.
I'm quite tempted to dyno my car before and after to show the differences using a panel filter, R34 cooler, 3" exhaust... but it costs more money! =-[
Edited by RANDY
    • I had absolutely no symptoms whatsoever that anything was wrong.... I'm very happy it was all spotto'd and re-bled and re-torqued and aligned though. Will be picking it up tomorrow and undoubtedly be like "Oh, that clunk is gone" "Oh, the car really wants to drive straight" "Oh, that pedal feels better" "Oh, it feels like I've gained 25hp" "Oh, the handbrake works now" It should have been a sign that the new Project Mu shoes had 3mm of pad depth on them out of the box, and the OEM ones from 25 years ago that we took out also had 3mm of pad depth, implying the issue was not, and never was the shoes, but we put that down to it not being adjusted correctly. It wasn't, but it wasn't even adjustable at all given one side was boned and the T Junction of the cables was on a 45 degree angle, the non-working side being the one on the massive angle. Obviously when I had adjusted it and reset it and re-tensioned it I had either got it stuck or something along those lines. Oh well. Live and learn and absolutely could have been catastrophically worse so I'm rationalizing it as a win, kinda. I also got the chance to measure the distance between rear rim and the suspension arm/shocks and found a 30mm rubber block only just doesn't fit there. Which is great to know before ordering wheels, when I assumed 30mm was easy. The man with the Porsche adapters has rims that use 23.9mm of that space, so it's safe to assume I have between 23.9 and 29.9mm of space there to play with on the inside. The wheels looked pretty stupidly pokey with the 20mm spacers on the rear, only for me to find that the studs come out another 12mm and the wheel doesn't actually sit flush with the hub because you're supposed to cut your original studs. The wheels do have cutouts that kinda accomodate it, but not fully. So my 20mm spacer was anywhere between 25mm and 35mm. ~25mm and send it will determine on where the wheels sit with the spacers on. When I put the pads in for the track day I will mess around with spacers (with wheels that do not clear studs properly when mounted to spacers) and do more math, for the last time, for the 7th time.
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
