has anyone got a mechanical boost gauge connected and if so where did u run the nylon hose thruogh the firewall and where is it connected to in the engine bay? and where have u mounted it in the cabin??
any pics would be appreciated
thanks Brad B)
https://www.sau.com.au/forums/topic/99758-boost-gauge-connection/
On mine, the vacuum hose is connected to the rear of the plenum, there is an unused fittingthere that is the right size. The vacuum hose then goes out of the engine bay to the RHS guard, accross the rubber door seal and up the A pillar where the boost guage is located in a POD.
:starwars: cheers :)
So... If I want to use that one for my guage, can I remove the stock connection and use the nipple? That pipe on the Skylines just goes to the ECU somehow, right? It's not going directly to the guage on the dash? Cheers!
There is an unused nipple at the back of the plenum, take the rubber cap off it, connect the vac hose to it.
Run the vac hose past the firewall somehow, i used the big gromment next to the ABS, then run the vac hose to the guage.
Mount where desired, enjoy the b00st :D
It certainly doesn't go to the gauge in my R34 skyline (or S2 stagea) as the ECU knows the boost (which is why it comes up on my laptop as well as the central gauge..) and goes to the gauge in a wire :-)
Ian
Thanks, Ian! A mate told me the same thing, but I'm curious as to why I don't see any boost reading in any consult software that I try. I would also like to use that pipe to go directly to a boost guage that i'm fitting, rather than tap off something else.
The only real pipe I can see goes to the MAP sensor, I think. (it's tiny)
Most of the consult software out there is crap, written in VB by amateurs.. :P Mine will be out in a month or so (pm me your real email address and I'll send you a copy to test if you'd like) and includes everything you can get out of the port, not to mention real time graphing and 'replay' ability etc.. Written all in C++ :)
The only reason I've written it is that I've seen how bad the ones out there are...
And I guarantee the turbo boost IS coming out of my R34 consult port, as I have had it up on my screen many times while I've been testing my software!
Ian
Ian
Hi Ian, there is no MAP sensor on my Stagea S1, the ECU has no way of knowing the boost level. I will be very interested in having a look at your Consult software when it is available.
;) cheers :spank:
Edited by Sydneykid
Ah! Thanks Ian and SK! That answers my question. The unused nozzle on the back of the manifold on a Stagea is what the Skyline uses to go to the MAP sensor.
Ian, PM sent... i'd love to monitor my boost digitally! =-]
;) cheers :rofl:
Yep, as per usua,l you are correct - tried it on a series 1 stage today and the things it could get were -
Live Register,Description
X00,RPM
X01,RPM part2
X04,Airflow
X05,Airflow part2
X08,Water Temp
X09,O2
X0b,Speed km/h
X0c,Battery
X0d,Throttle
X12,Exhaust Temp
X13,Bit_Reg1
X14,Injection Time
X15,Injection Time part2
X16,Timing (degree BTDC)
X17,Idle Air Valve %
X1a,AF Alpha %
X1c,AF Alpha Learn %
X1e,Bit_Reg2
X1f,Bit_Reg3
X21,Lean
Finished.,Version 1.10
Where as the series 2 can get -
X00,RPM
X01,RPM part2
X04,Airflow
X05,Airflow part2
X08,Water Temp
X09,O2
X0b,Speed km/h
X0c,Battery
X0d,Throttle
X13,Bit_Reg1
X14,Injection Time
X1a,AF Alpha %
X1e,Bit_Reg2
X1f,Bit_Reg3
X21,Lean
X26,Tank Temp
X29,Turbo Boost
X3b,Unkown_X3B
X3d,Unkown_X3D
X3f,Unkown_X3F
X40,Unkown_X40
X43,Unkown_X43
X44,Unkown_X44
X45,Unkown_X45
X46,Unkown_X46
X62,Unkown_X62
X63,Unkown_X63
Finished.,Version 1.05
ie includes the turbo boost, and a stack of other things that we don't know what they are (I'm hoping one is front/rear torque split :P
Ian
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
