has anyone got a mechanical boost gauge connected and if so where did u run the nylon hose thruogh the firewall and where is it connected to in the engine bay? and where have u mounted it in the cabin??
any pics would be appreciated
thanks Brad B)
https://www.sau.com.au/forums/topic/99758-boost-gauge-connection/
On mine, the vacuum hose is connected to the rear of the plenum, there is an unused fittingthere that is the right size. The vacuum hose then goes out of the engine bay to the RHS guard, accross the rubber door seal and up the A pillar where the boost guage is located in a POD.
:starwars: cheers :)
So... If I want to use that one for my guage, can I remove the stock connection and use the nipple? That pipe on the Skylines just goes to the ECU somehow, right? It's not going directly to the guage on the dash? Cheers!
There is an unused nipple at the back of the plenum, take the rubber cap off it, connect the vac hose to it.
Run the vac hose past the firewall somehow, i used the big gromment next to the ABS, then run the vac hose to the guage.
Mount where desired, enjoy the b00st :D
It certainly doesn't go to the gauge in my R34 skyline (or S2 stagea) as the ECU knows the boost (which is why it comes up on my laptop as well as the central gauge..) and goes to the gauge in a wire :-)
Ian
Thanks, Ian! A mate told me the same thing, but I'm curious as to why I don't see any boost reading in any consult software that I try. I would also like to use that pipe to go directly to a boost guage that i'm fitting, rather than tap off something else.
The only real pipe I can see goes to the MAP sensor, I think. (it's tiny)
Most of the consult software out there is crap, written in VB by amateurs.. :P Mine will be out in a month or so (pm me your real email address and I'll send you a copy to test if you'd like) and includes everything you can get out of the port, not to mention real time graphing and 'replay' ability etc.. Written all in C++ :)
The only reason I've written it is that I've seen how bad the ones out there are...
And I guarantee the turbo boost IS coming out of my R34 consult port, as I have had it up on my screen many times while I've been testing my software!
Ian
Ian
Hi Ian, there is no MAP sensor on my Stagea S1, the ECU has no way of knowing the boost level. I will be very interested in having a look at your Consult software when it is available.
;) cheers :spank:
Edited by Sydneykid
Ah! Thanks Ian and SK! That answers my question. The unused nozzle on the back of the manifold on a Stagea is what the Skyline uses to go to the MAP sensor.
Ian, PM sent... i'd love to monitor my boost digitally! =-]
;) cheers :rofl:
Yep, as per usua,l you are correct - tried it on a series 1 stage today and the things it could get were -
Live Register,Description
X00,RPM
X01,RPM part2
X04,Airflow
X05,Airflow part2
X08,Water Temp
X09,O2
X0b,Speed km/h
X0c,Battery
X0d,Throttle
X12,Exhaust Temp
X13,Bit_Reg1
X14,Injection Time
X15,Injection Time part2
X16,Timing (degree BTDC)
X17,Idle Air Valve %
X1a,AF Alpha %
X1c,AF Alpha Learn %
X1e,Bit_Reg2
X1f,Bit_Reg3
X21,Lean
Finished.,Version 1.10
Where as the series 2 can get -
X00,RPM
X01,RPM part2
X04,Airflow
X05,Airflow part2
X08,Water Temp
X09,O2
X0b,Speed km/h
X0c,Battery
X0d,Throttle
X13,Bit_Reg1
X14,Injection Time
X1a,AF Alpha %
X1e,Bit_Reg2
X1f,Bit_Reg3
X21,Lean
X26,Tank Temp
X29,Turbo Boost
X3b,Unkown_X3B
X3d,Unkown_X3D
X3f,Unkown_X3F
X40,Unkown_X40
X43,Unkown_X43
X44,Unkown_X44
X45,Unkown_X45
X46,Unkown_X46
X62,Unkown_X62
X63,Unkown_X63
Finished.,Version 1.05
ie includes the turbo boost, and a stack of other things that we don't know what they are (I'm hoping one is front/rear torque split :P
Ian
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
