Hey guys I've been watching and studying for sometime but i still don't have the answer so i thought i'd ask and hopfully with enough expertise out there you can help illustrate what might be an approporiate start.
I'm importing an GTR 33 (though Imports101 in WA nissans especially R33 compliance is so easy for them ) with the titled parts (T88H 34D with Tomei 2.7 kit) I mean plus the needed support bits (oil cooler, big intercooler, 1000ccs, surge tank and multiple fuel pumps etc) probably cross mission too.
But when it gets here I'm not sure what work must be done when buying a second hand beast (by this i mean highly modified). It's supposed to be running 800-1000hp but we all know about hp figures hehe. I have already ordered a custom (JUN copied with bolstered ram shaft) plenum.
My understanding would be
1. Check stoker kit, shot peen crank?, change conrod bolts?, balance conrods, polish pistons?
2. check dump pipe for hughness, exhaust etc
3. Check T88 maybe high flow turbo?
4. what else? :starwars:
Please keep in mind budget so some sort of order of what to do would be cool, I'm juiced to get this because this time last year I almost bought a JUN 2.7 R34 but missed it.
If you wold like a look http://www.centralmotor.net/web/detail.php?num=152
So do i check everything or just some things if so what is an absolute must, to be checked what is something that can wait or isn't too important?
Darryl
PS outcome is daily drive drag/street car
https://www.sau.com.au/forums/topic/99766-t88h-34d-with-tomei-27-what-to-do/
Congrats on the buy dude, sounds like a bit of an animal..
as for what to do, well, engine wise you shouldn't have to do anything, to get the extra stroke you need a different crank <usualy> so id peg that the motor already has a billet crack, rods and pistons, big cams, and probable a hoard of other fruit internally to support the power...
however, if your paranoid, and i know i personally would be, id be pulling the motor out, and stripping it down to check everything to make sure its in good working order, and giving it a new set of rings and bearings, depending on how long its been together for, unless you can get accurate info from the guys in japan about it, it'll save the not knowing factor...
as for everything else, personally id leave it alone, and id just look about getting it re-tuned for australian fuel, thatd be priority number one once your sure about the quality of the internals, then you will see what it can do, and if you need to touch anything to get more out of it...
Looks good, i dont like the mission your gonna have of getting it complianced tho...
It would be a good idea to rip the motor down and have a look at everything and see whats going on internally and to give it a freshen up.
Sometimes te cars are meant to be "internally" modded but when they get here and pop you find out they werent.
leave the plenum, no need to change that
High flow a T88-34D
Good son of rajab dude... You certainly dont wanna be doing that!
I'd personally be changing the turbo if you wanna have some street use.
Something like a HKS T04Z... they seem to be doing amazing things and would make a super streeter.
For more info in T04Z - use the search button as there is a great thread on it all.
No need to pull the engine.
Do a leak down test, that will tell you what sort of condition the pistons, rings, bores, valves, head gasket etc is in.
Then take an oil sample and send it for analysis, that will tell you what sort of condition the bottom end is in, bearings, crank, rods etc.
If everything tests OK, then run it up on the dyno and check the A/F ratios, knock, power etc
If everything is OK, then get on with driving it.
:starwars: cheers :)
not to spoil the mood or anything.
but there WILL be a problem complying that.
just a gues youl need these parts.
non braded brake lines
posibly brake calipers/discs
engine
wheels
seats
and pretty much anything else non standard.
just make sure you know were the raws auditers are so they can submit the paperwork when their on the otherside of the country.
sick car but MASSIVE job.
oh. the engine should be fine. :lol:
MMMmmm...yummo engine,but I'll mirror earlier comments,tho':good luck getting that beast complied! Oh,yes:
As you need MORE flow than a T88 provides?LOL!
Denver: R31Nismoid: Sydneykid: I know I know i just haven't imported before so I'm like what to do. Anways thanks a mill you guys for posting it helps confirm things big time.
T04GTR: The import co will compliance as I said they do R33's easy, plenty of the vanialla R33 parts nps there.
Fast GTR: it comes with PFC and commander already but thinking wolf cos nos, antilag and rotational i.
Thanks again
D
ill say, the work to strip the car to compliance condition is going to be huuuge
the interior is 100% stock apart from a torque spliter/power FC/one gauge and a remote start in the glove box.
So it'll just be the exterior and hey wish me luck and no pain please
BTW Nismoid are you familiar with how much it is to be a sponsored banner ad PM me please or Blitz if you know.
Just becasue a piece of paper says 'this is whats in the car' doesnt exactly mean everything is in there.
Strip the motor down. This is the only way you will know for sure what is in the engine. Then (and only then) you can decide how hard you want to lean on it. Your engine builder can then set the desired clearances, tolerences, compression ect based on what is ACTUALLY in the engine and what you want the car to do. It is alot cheaper than tuning the car based on what you 'think' is in the car and then having it go bang.
I would assume its a standard & prepped crank.
I thought the normal Power FC needed AFM's?
thnx purple R32 agreed
Its D jettro thats why
and hey NXTIME I don't think mine is an LM just a vspec but that looks sweet where did you find it?
Edited by skyphun
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
    • Unfortunately, not only is that not the case, one of the main "Selling points" of safety over comms is they clearly state in writing that there's no need to segregate safety networks from non-safety networks. It always gets intermingled with everything else on an ICS/OT network.
    • Hello. I have an a31 cefiro but since I am in Turkey we have a CA20S engine. I did some research. Then I found that I can swap with a ca18 but when I heard that it has the similar substructure as the s13. I thought I can swap with an sr20 because the sr20 was used with the s13. So can I easily swap the sr20 on my cefiro or is it difficult?
    • I used to love stock take. I used to take f**k of a lot of stock. /Rodney Rude.
