Who Sells R32 Clear Indicators ?
Hey SAU
Im After a set of clear indicators for an R32 Gts-T, i have seen them around on the cars but havnt been able to find them, i know many other people are interested in these also.
So is there anyone in australia selling them or where else i can purchase them from ??
Im also after a gtr grill, dose anyone make aftermarket ones of thses as i am having trouble finding a genuine one.
thanks.
tours.
Edited by Tours
https://www.sau.com.au/forums/topic/99769-who-sells-r32-clear-indicators/
they wont fit your GTSt
they are D-Speed indicators and are made for GTRs only
ive got em on my car and after conparing em with a set of GTSt indicators they are significantly wider and therefore wont fit your GTSt guards
could always get the ones like on mine... 90% clear
i was going to throw em out cause the nob that connects to the panel is broken... but then saw how hard it was to find more so will no just repair it with some resin :P
take screw driver, jam inside hole, smash, repeat until satisfied.
really easy :P
or you could do it the long way, follow my DIY guide:
http://www.skylinesaustralia.com/forums/in...showtopic=42193
either way check that thread, you should be able to see the orange cover inside that we're talking about.
and they end up looking better imo then all clear anyway... just dont put red globes in there like the previous japanese owner of this car did... looks kinda queer
yeh we took it apart and took it out of my mates just before, easy :)
Did u put orange globes in or clear globes that go orange.
Will be disecting mine when they get here next week
pz
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
