Who Sells R32 Clear Indicators ?
Hey SAU
Im After a set of clear indicators for an R32 Gts-T, i have seen them around on the cars but havnt been able to find them, i know many other people are interested in these also.
So is there anyone in australia selling them or where else i can purchase them from ??
Im also after a gtr grill, dose anyone make aftermarket ones of thses as i am having trouble finding a genuine one.
thanks.
tours.
Edited by Tours
https://www.sau.com.au/forums/topic/99769-who-sells-r32-clear-indicators/
they wont fit your GTSt
they are D-Speed indicators and are made for GTRs only
ive got em on my car and after conparing em with a set of GTSt indicators they are significantly wider and therefore wont fit your GTSt guards
could always get the ones like on mine... 90% clear
i was going to throw em out cause the nob that connects to the panel is broken... but then saw how hard it was to find more so will no just repair it with some resin :P
take screw driver, jam inside hole, smash, repeat until satisfied.
really easy :P
or you could do it the long way, follow my DIY guide:
http://www.skylinesaustralia.com/forums/in...showtopic=42193
either way check that thread, you should be able to see the orange cover inside that we're talking about.
and they end up looking better imo then all clear anyway... just dont put red globes in there like the previous japanese owner of this car did... looks kinda queer
yeh we took it apart and took it out of my mates just before, easy :)
Did u put orange globes in or clear globes that go orange.
Will be disecting mine when they get here next week
pz
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
