This mite be a stupid question but as far as i know the V8 supercars use a spark plug near the end of their exhausts to create the fire you see out the back...i think this is there so it creates some sort of back pressure or something like that...
i guess wat i'm asking is if we were to place a spark plug near the end of our exhausts wouldn't that cause a pull of air through the turbo on gear changes keeping it spinning.
i'm not looking to do this for the rice factor just interested if it would work and how i wud go about doing it.
also would there be a way to turn it on and off.
thanks for any feedback...also be nice with replys i'm learning still.
cheers, Mark
https://www.sau.com.au/forums/topic/99774-faster-spool-up/
you can use aftermarket 3rd party tools to help assist with turbo lag and "spooling up" if this is what you are referring to? I suggest you do a search on anti-lag. the idea is to retard the timing and dump fuel on gearchange to keep the exhaust housing spinning and so when you come back on throttle the turbo is still spinning at a higher speed that it would have been when you back off throttle the normal method. the result well in theory is not as much lag as the turbine is still running at a high speed, enough to bring the compressor back into its efficiency zone quickly
https://www.sau.com.au/forums/topic/99774-faster-spool-up/#findComment-1817534
Back pressure is not something you want in a turbo setup. That will increase lag, not decrease it.
So, logically speaking, if the V8 Supercars were igniting fuel in the exhausts to generate back pressure...it would be counter productive on a turbocharged car. It wouldn't "pull air" through the exhaust - it would just block it.
Of course, as people have said above its not the case. You can blow flames just as easily in your car by pulling out your cat and running non-baffled mufflers. Just rev the car hard and pop off the gas.
https://www.sau.com.au/forums/topic/99774-faster-spool-up/#findComment-1818662
A fair few pro off-street race cars will run anti-lag. Most involve dumping excess fuel on throttle-off (normally by running it rich and taking timing out), and will either use a spark plug in the turbo's exhaust housing or rely on the hot turbine itself to ignite the fuel.
Normally they'll use an aftermarket ECU, so you can program and choose what conditions you want the anti-lag to kick in.
Aside from being very street illegal, you have to be a pro racer to run such a setup since your turbocharger then becomes a consumable. There's few faster ways of f**king your turbo's wheel than causing explosions on them.
https://www.sau.com.au/forums/topic/99774-faster-spool-up/#findComment-1818665
like i said it was just someone telling me they had been wondering about it who maybe doesn't know much at all. ohwell was worth asking...i didn't think it sounded right hence the "be nice with ur replies" part
https://www.sau.com.au/forums/topic/99774-faster-spool-up/#findComment-1818870
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
