Can i install it and boost up a lil tiny bit? bcos its sitting and im so tempted to install it lol... What are the precautions? can it stuff up anything obviously if i do it to hight then yeh.. but maybe just 2-3psi more? is ok?
Geraus, Thanks.
  • Replies 42
Posted Images
Geraus, I fitted my profec B II to my 34 and am currently running 10psi with the stock cooler and just a turbo back exhaust. No problem at all :miner:
The unit is very easy to install, first one ever and the hardest part was routing the tube through to the engine bay! haha
If you want to know anything just ask away and Ill help if I can!
Cheers!
I installed mine ages ago, but since have installed a PFC & had a dyno tune
You could try boosting it a bit but set the limiter to 11PSI
I found that it wouldnt boost that well and to the desired PSI until i had the PFC installed & dyno tuned
Im thinking of doing it over the weekend, still brand new in the box... Just worried because im still kinda confused with the Greddy/Trust solenoide.. it has 3 holes.. im confused wot connects to them.. i mean looking at my stock solienoid it only has 2 pipes connected to it... why does the stock trust/greddy one have 3? or what is the 3rd hole ? do i need to connect it or na?
Thanks guys,
Geraus.
The hole that is not used is there for if you have an external wastegate. In which case one of the holes being used for an internal wastegate type turbo would become spare.....that make any sense??
I found the instruction manual to be pretty good and made things fairly simple to understand.
  • 4 weeks later...
Hey i installed it ! finally! im running it stock! just a poddy! i dont know how to conifgure it :/ if anyone knows could they tell me? like i set it to 10psi then when it reaches it! it goes back to 5 or 6psi its really wierd :D but when i full pushes it chucks or missing a fire its weierddd... Im also very confused with the HI and LO? what is it for?
Edited by geraus
  • 1 month later...
  • 4 weeks later...
  • 1 month later...
  • 9 months later...
  geraus said:
Hey i installed it ! finally! im running it stock! just a poddy! i dont know how to conifgure it :blush: if anyone knows could they tell me? like i set it to 10psi then when it reaches it! it goes back to 5 or 6psi its really wierd ;) but when i full pushes it chucks or missing a fire its weierddd... Im also very confused with the HI and LO? what is it for?
I have the same problem with my Profec II. Grateful if someone can post their setting. Mine's stuck at 35% gain and can't go any higher in both HI and LO settings. Beginning to wonder if the problem is with my unit until I see your post. I think as soon as the controller sees the preset warning boost, it cuts everything back to 0.5bar. I'll try to play with the settings again tonight.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
