  • 11 months later...
  • Replies 42
Posted Images
The GReddy Profec B-Spec 2 is becoming one of the more popular EBCs around and since I had one installed I thought I'd post a really simple photo guide on how install should look like on a RB25DET engine.
Picture 1
- The GReddy solenoid fully replaces the stock one.
- Black hose from the actuator goes to the GReddy solenoid as shown
- The red hose attached to the GReddy solenoid goes to Picture 2
- Electrics are wired up simply as shown.
Picture 2
- This photo is located at far end of the plenum, next to the BOV.
- The bottom red hose attached to the T-piece comes from the solenoid in Picture 1
- The right red hose goes to the plenum as shown.
- The black hose on the left goes to the BOV.
Picture 3
- This photo is located at near end of the plenum, next to the wiper washer bottle.
- The bottom hose with the filter attached goes to the main control unit inside the cabin.
- Other hoses are put together simply as shown.
Hope this helps some of you during a DIY install.
can you please repost pictures please... would be great...
hey guys, can someone tell me what colour wires to connect at the sensor as i need to hard wire it in as i dont have one of the connectors to join the harness together.unit harness is green and white, valve unit is black and red.
any help is appreciated, thanks
    • The cross sectional area of a circular hole scales with the square of diameter. So a 2mm diameter hole is 4x the area of a 1mm hole. Not double. The 1.7mm hole is nearly 3x the area of a 1mm hole. You do not need restrictors at both ends of the oil supply line. If you have new, additional restrictors at the turbo end, that you did not have before, then you do not need a restrictor at the inlet end.
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
