Hi there folks,
I have had an incident with a large stone chip which has cracked the windshield on my 1996 Stagea,
Could anyone please tell me who in brisbane will replace window, as i will be doing it through insurance ,
I heard on the grapevine that these front windows are the same as R34 ?!? is this correct,
If anyone can help please post details of places as i would like to get this done for this years window on my policy /?
Regards,
Ashley Neal.
https://www.sau.com.au/forums/topic/99792-windshield-replacement/
I think one of the other guys got his replaced at Novus @ Burpengary if i remember correctly, I don't think they are the same as a R34 but I've talked to this guy and he tells me he can get a windscreen for a stagea, somewhere around $300 fitted, but don't don't quote me on that.
Beastien.
Sounds good i'll take a burl over there 2morra - it's only 15mins away
Thanks.
Beastien.
Yeah do a search...
http://www.skylinesaustralia.com/forums/in...=87852&hl=novus
I did mine under insurance and Novus @ Burpengary were great, wonderful service and would recomend them to anyone in the Brisbane area needing a replacement windshield!
    • Appreciate the feedback. It is street car, but not a daily. Last week I got a quote from a good exhaust shop for a decat, one which is bolt-on, bolt-off to be easily replaceable. I got quoted for around €150. I usually do push the motor, but I wasn't in this case to make sure that no damage is done until I get the cat sorted. I think it's best to also ask the exhaust shop for the other option and see what they can do. If (big if) I were to decat though, would it be best to tune the car or would the stock ECU handle it? As far as I know, the stock ECU is not tunable and that would require additional purchases.
    • As above, definitely bash it or get it replaced with a high flow unit.
    • get some flares on them, or wider guards haha
    • Another question sorry, what stainless do u use in the turbo external WG plumb back piping? Is it 321, 316 or 304?
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
