sumtimes wen i gun my car hard i see white smoke come out from the launch, and once after a serious trashing white smoke comes out from the exhaust for a bit n goes away when idling, but most off the time racing ders no smoke or sumtimes dark brown, (only been running ultimate n optimax)
i just bought the car n its been running at least 14psi+ on factory parts besides pod n 3'' exhaust, according to the factory hg gauge with 140000 km
any ideas guys?? could it be signs of detenation??
https://www.sau.com.au/forums/topic/99803-white-smoke-from-exhaust/
brownish/black smoke = running rich
white or blue smoke = burning oil
Sounds like you have a bit of blow-by, symptoms of a leaking seal in the turbo or a tired engine. Running 14psi+ on a std turbo, i would suggest you start saving for a replacement :)
thanks guys, yea thought it could be a screwed engine, but it only happens sumtimes though, n sum guys reckon white smoke sumtimes is normal or even good for the engine, does this sound liable???
wud a compression test tell me if the engine is f*ked, if so how much wud it cost???
btw what is condensation???
by condensation i meant , for example when someone washes their car and the exhaust system gets wet...it'd burn off the water and make some smoke or steam which will look smokey....or when the car is cold etc...but yeah, doesnt sound like thats what u've got unfortunately
Condensation is when, on a cold day/night, water droplets build up in the exhaust. Then evaporates when the exhaust heats up (white stem comes out of exhaust). This only happens on the first startup of the day.
It is more likely that your turbo has a leaking seal. Any reasonable performance mechanic can do a comp test on the eng. and check the turbo for you.
I do not beleive white smoke can ever be good.
But no need to panic, get it checked out, as these things could last for months/years just like it is.
also if it has a blow by (which sounds like the case) shud i be taking my car easy n would it be possible to get this problem fixed up before it gets worst, like maybe a bottom end rebuild or isnt there much point, shud i just drive it until the engine blows, pls tell me what u guys think im lookin at here???
Things to do: (in my order of preferance)
1/ Get turbo and eng checked by a good mechanic
2/ If blow-by is not too bad, ask mechanic to fit a quality "oil catch can".
3/ Empty the "catch can" weekly and keep note of how much oil is being used. Note: Always dispose of oil and top up eng. with fresh oil of the same brand and class.
4/ If turbo seizes, then replace it. Or save up for an upgrade :(
5/ Once the engine feels tired then rebuild it, no point in doing it now if you can't afford it or if the turbo is the problem.
NOTE: Could also be the valve stem seals in the head, leaking oil onto the pistons. So don't panic and take it to a decent mechanic.
Sounds like a turbo to me.. happened to my brothers turbo-charged VTi-R honda civic. He was using a rb20det turbo, and it was tired to begin with.
Is your car running a catalyic converter? Because my brother took his out (was restrictive) and he then got the white smoke problem (only had a little blue smoke before on full boost ~ 10.7PSI)
If your not too sure, take it off and check that it hasnt been gutted... if it has, fit a standard catalyic converter back on (restricts it) and the majority of the smoke shall go away. I cant remember the reason why more smoke etc came out after he took it away, something to do with no back pressure.
This is only a temp fix, and i suggest you do start saving for a new turbo... but this might get you a little longer life out of it. Goodluck mate.
Dayne
thanks guys for all ur help, n yea its the turbo, looks like saving for me $$$, btw ne1 knos wat is the best turbo to fit to the std flange, i heard T3 are a straight fit for a good replacement?? n would i have to sav up for a fmic n boost controller too??
If you are going for a bigger turbo, and there are plenty on the market that fit in the std location, you will need to upgrade the following:
- injectors
- ecu
- fmic
- fpr (fuel pressure regulator)
- exhaust
- oil & water lines, to the turbo
May have missed a couple, but it certainly is not as cheap exercise.
All the best!
White smoke can also be coolant leaking in to the cylinder's.
The best thing to do is trouble shoot.
1. Remove your intake and check for oil around the impeller blades. Also check for shaft play. Wiggle the shaft and listen carefully for any noises or excessive movement.
2. Check your I/C piping and throttle body area for oil.
3. Remove your spark plugs and check them.
- if they are just slightly black thats good.
- if they are white, your burning coolant and it could be your head gasket.
- if they have oil, your burning that and it's probabley a valve seal.
Doing all of this should hopefully source your problem. I had a similar issue like yours with my ka-t in my 240. It only smoked under boost and I narrowed it down to my turbo being toasted. I did all of the checks though (that I mentiioned above) to pretty much 100% confirm the problem.
Good luck man and hopefully it's nothing major.
Cheers
Ok, I have a blown turbo on the Stagea, I had to drive a few blocks to get some fuel, driving very sedatly, I noticed a thick white haze behind the car. Ok, now I realise i shouldnt be driving the car, but tommorow is our annual show and shine which I have a place/set booked. Is prob about 6k's from my house, if I take it very easily, will it cause any major damage to my car?
Make sure your topped up with oil, take some with you, watch your oil pres gauge and DO NOT pump on it and you'll be fine. Try your best not to make boost and no high rev's either.
Do all that and you'll be fine without causing any damage to your motor.
I had the same problem on my old 240 and drove around for just over a month and had no prob's.
Good luck at the show. :P
Cheers B)
I dont know how you wash your car mate but in all the years ive owned a car thats never happened. White smoke sounds like your turbo gasket is shagged.
Only time ive ever had steam is on a cold night and when the car first starts up after not been drivin for awhile.
    • Yeah, thumbsup from me. The distant shot of the bay just looks same-same as before.
    • Dad had a court case drag out with them from 1998 to 2004. He was in a not at fault accident, NRMA were the ones who covered the other person. They tried to blame his neck injuries on the fact he'd had an injury in 1981 on his extreme lower back where he slipped a single disc right near the bottom. Had been all cleared from that injury for years. This accident destroyed his shoulder, and f**ked a heap of discs in his neck, and he still has major problems with it to this day. Sarah's sister while on her L plates had a small Suzuki Alto, she had stopped to give way to an ambulance, and someone changed lanes behind her because there lane was also slowing, and rear ended her at 80km/h. (She had been stopped for a few seconds already too!). Car was completely f**kED. NRMA sent the vehicle around to 3 different workshops as they kept claiming "We believe it can be repaired, and not written off, we just need to find the correct workshop". It took 3 months, and a lot of arguing before they'd concede and wrote it and paid out. About two years later her sister had a Lancer, someone pulled out of a stop sign without stopping (in an 80 zone). Her sister swerved, hit the front of the other persons car (Instead of dead t-boning the drivers door), which ramped her Lancer, and made it roll multiple times down the road. It hit every panel on the way through. Her sister had slid her self out of the car, and remembers the ambos walking to the accident (They'd been sitting at a set of lights just down the road and witnessed it) and they were saying "Well, this ones going to be a fatality, no way you can walk away from that". Well, she did. And then NRMA sent two assessors out to look at the car, both of which wrote it off. They tried to send another assessor out, except a HUGE uproar was raised, and they FINALLY paid it out. That was on a car, that had damage to EVERY panel, you could see from 100m away the whole car was also twisted, roof bowed etc. Nah, we'll try get out of needing to payout on a $10,000 car... Her sister ended up with major shoulder reconstructive surgery being required, and was permanently limited in her ability to do her job as a nurse after that, as she can't (And was told before surgery too this would be guaranteed to happen) regain full strength in that shoulder. However, there was no choice to not have it, as she could barely use her arm, which was her dominant one, and was in near constant major pain. (And she's the type of person that would try and walk off a broken leg!) NRMA did the biggest run around on the personal injury side too for about 18 months, even to the point of trying to put 100% blame of the accident on Sarah's sister, even though the other driver admitted she didn't look, and didn't stop, and was charged by the police. Sarah used to have a Barina insured with them. It was a policy setup, paid all 12 months in advance. At the end of the 12 months, Sarah was living with me, I reviewed the renewal, it clearly stated "If you do nothing, your policy will cease on XYZ date". We did nothing, as we moved her insurance in with all of mine and I was with Shannons. We find out 10 months later, NRMA decided, because he DAD had a car insurance policy at the same address as what Sarah's mailing address was (Garaged address had been changed), that they'd put Sarah's (What should have been non existent policy) onto her Dad's month to month charges on his credit card. We had to jump through hoops, to get a refund. They didn't care that we actually found the letter that said "If you do nothing, your policy will cease" they made us prove we had NON COMPULSORY insurance else where before they'd issue the refund, and after they agreed to the refund, it still took another 6 weeks and 3 more phone calls for them to actually process it. They also had two insurance claims from storm damage, and they were an absolute cluster to get resolved as well (one vehicle, one house). Some how, up until about 3 years ago, her parents were still loyal to NRMA too, and we were like "How the hell are you so loyal to staying with them, when other places are so much cheaper, and they've f**ked you over every time you've ever had to make a claim?"
    • I got the four AN10 fitting welded up to the cam covers and started up making the head to sump breather/drain lines. The front passenger side cover I used a 45 up top and a 90 at the bottom into the stock VCT head drain spot (3/4" BPST to AN10 adapter) thats unused on the RB25DET NEO with some speedflow flame shield to protect it from the manifolds heat.   back passenger side was a 90 up top with some flame shield and 45 at the sump end. The rear drivers is 45 at both ends   the front drivers fitting is capped off for now but ready to go if i want to try moving the breathers around. I was told by the fabricator to leave all the welds raw for now to make sure there are no pin hole leaks. A lot of cleaning up, re bundling looms and degreasing to go as well as final assembly on the cam cover baffles. The first real test will be 28th March at a Circuit event. added complexity and more spots for leaks but overall looks relatively neat imo
    • Yeah i think the dash needs to come out. To get the loom or maybe just climate control and radio cluster. My mirrors are done i think the motors don’t work so well after flood haha i need the ac fan, you said you wanted to keep it for your 31 and interior loom not including boot. The wiper motor. I’m not sure how good the window surrounds are on the exterior on the pintara.  I will message you to get your bank details shortly
    • Just another barrier put up to stop cars being modified. When we're all driving Chinese sewing machines, you won't want to modify it anyway, and you'll likely already have slashed your wrists and be locked up in a padded room for your own protection.
