Anyone know who can replace the rear windscreen seals on a R32GTR???...
Rear screen is bonded in place like the front, I think. There's no rubber seal as such. Best thing would be to talk to a windscreen specialist and see what they would charge to remove and refit the old one. Will have to be done carefully as the rear screen is tempered glass which shatters easily.
Rear and front windscreens are both bonded (with sealant) and sealed with rubber seals.
New rubber seals can be purchased through Nissan, but are not cheap and may need to be ordered from Japan. These can be fitted by most major car windscreen replacement companies.
Alternatively you car take your car to a windscreen replacement depot and ask if they have a generic rubber seal that would do the same job. This may not look 100% factory, but shouldn't be a real problem, and it will be cheaper and quicker :(
There are no rubber 'seals' as such with the front windscreen on an R32 GTR and I believe the same is true of the rear. The windscreen is bonded in place and the bonding agent (essentially a type of silcone) also forms the weather seal. There are also various plastic channels and spacers which are used to locate the windsreen and attach the outer trim and these are sometimes called 'seals', but they actually don't 'seal' anything as such. And yes, they are also expensive.
I've had the front windscreen replaced on my R32 GTR and I was there when it was done. No rubber seals were present nor needed to be replaced.
I'm curious on this, what is the statute requirement for a car manufacturer to continue to make replacement parts available for older cars? up to 15 years? I thought it would be less than that.
hehe Al, relax dude.. i was just curious if car manufacturers had a legal requirement to be able to supply spare parts for their cars for a certain period of time.
i had my front windscreen replaced recently, found out the genuine nissan garnish that goes around the windscreen is $600 :) hehe so i just reused the original one.
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
