rickhead Posted December 27, 2005 Share Posted December 27, 2005 Anyone know who can replace the rear windscreen seals on a R32GTR???... Link to comment https://www.sau.com.au/forums/topic/99817-rear-windscreen-seals/ Share on other sites More sharing options...
SteveL Posted December 27, 2005 Share Posted December 27, 2005 Anyone know who can replace the rear windscreen seals on a R32GTR???... <{POST_SNAPBACK}> Rear screen is bonded in place like the front, I think. There's no rubber seal as such. Best thing would be to talk to a windscreen specialist and see what they would charge to remove and refit the old one. Will have to be done carefully as the rear screen is tempered glass which shatters easily. Link to comment https://www.sau.com.au/forums/topic/99817-rear-windscreen-seals/#findComment-1817875 Share on other sites More sharing options...
Al Posted December 27, 2005 Share Posted December 27, 2005 Rear and front windscreens are both bonded (with sealant) and sealed with rubber seals. New rubber seals can be purchased through Nissan, but are not cheap and may need to be ordered from Japan. These can be fitted by most major car windscreen replacement companies. Alternatively you car take your car to a windscreen replacement depot and ask if they have a generic rubber seal that would do the same job. This may not look 100% factory, but shouldn't be a real problem, and it will be cheaper and quicker Link to comment https://www.sau.com.au/forums/topic/99817-rear-windscreen-seals/#findComment-1817970 Share on other sites More sharing options...
SteveL Posted December 27, 2005 Share Posted December 27, 2005 Rear and front windscreens are both bonded (with sealant) and sealed with rubber seals. <{POST_SNAPBACK}> There are no rubber 'seals' as such with the front windscreen on an R32 GTR and I believe the same is true of the rear. The windscreen is bonded in place and the bonding agent (essentially a type of silcone) also forms the weather seal. There are also various plastic channels and spacers which are used to locate the windsreen and attach the outer trim and these are sometimes called 'seals', but they actually don't 'seal' anything as such. And yes, they are also expensive. I've had the front windscreen replaced on my R32 GTR and I was there when it was done. No rubber seals were present nor needed to be replaced. Link to comment https://www.sau.com.au/forums/topic/99817-rear-windscreen-seals/#findComment-1818013 Share on other sites More sharing options...
Downforce Posted December 27, 2005 Share Posted December 27, 2005 New rubber seals can be purchased through Nissan, but are not cheap and may need to be ordered from Japan. These can be fitted by most major car windscreen replacement companies. <{POST_SNAPBACK}> I'm curious on this, what is the statute requirement for a car manufacturer to continue to make replacement parts available for older cars? up to 15 years? I thought it would be less than that. Link to comment https://www.sau.com.au/forums/topic/99817-rear-windscreen-seals/#findComment-1818287 Share on other sites More sharing options...
ylwgtr2 Posted December 28, 2005 Share Posted December 28, 2005 the screens are glued in with urathane.....there is a weather mould...they are about $180 dollars fom nissan Link to comment https://www.sau.com.au/forums/topic/99817-rear-windscreen-seals/#findComment-1818986 Share on other sites More sharing options...
R31Nismoid Posted December 28, 2005 Share Posted December 28, 2005 rickhead... your chasing a lot of parts at the moment, which are very similar Nissan has all you will need Link to comment https://www.sau.com.au/forums/topic/99817-rear-windscreen-seals/#findComment-1819186 Share on other sites More sharing options...
Al Posted December 28, 2005 Share Posted December 28, 2005 Geez........ Gotta get a bit technical Usaully spare parts stop production about 10yrs after the last car of that model is manufactured. But Nissan will still have stock available till they run out. Link to comment https://www.sau.com.au/forums/topic/99817-rear-windscreen-seals/#findComment-1820040 Share on other sites More sharing options...
R31Nismoid Posted December 28, 2005 Share Posted December 28, 2005 ive gotten HR31 parts before. Nearing 20 years now, and diff parts arent exactly "common" replacement. Worst case the Aust Dealership can get it from Japan Link to comment https://www.sau.com.au/forums/topic/99817-rear-windscreen-seals/#findComment-1820252 Share on other sites More sharing options...
Downforce Posted December 29, 2005 Share Posted December 29, 2005 hehe Al, relax dude.. i was just curious if car manufacturers had a legal requirement to be able to supply spare parts for their cars for a certain period of time. i had my front windscreen replaced recently, found out the genuine nissan garnish that goes around the windscreen is $600 hehe so i just reused the original one. Link to comment https://www.sau.com.au/forums/topic/99817-rear-windscreen-seals/#findComment-1822503 Share on other sites More sharing options...
Al Posted December 29, 2005 Share Posted December 29, 2005 Nah... First part of my previous post was aimed at SteveL's reply Link to comment https://www.sau.com.au/forums/topic/99817-rear-windscreen-seals/#findComment-1822755 Share on other sites More sharing options...
