  • Replies 67
Originally posted by sn00p
Mase - Yes I'm doing the conversion myself. I will get help with the wiring from a  mate who has done rb20 conversion, so that shouldnt be hard. 2.5k all up sounds fair for rb20 costs, but im putting a rb25 in, there is no use getting rb20 over sr20.
Ben
I'm the "mate" that's doing the wiring. The only reason he is getting an rb25 instead of a 20 is so he can beat me. Hopefully when we get the mods and boost even, we will be neck and neck. Maybe I might even try to rev my engine out more. We will have to see but there is no way I'm losing!
snoop... Its a pitty you couldn't get a RB30DET in there as a standard bottom end supplied and rebuild with standard internals and ACL bearings is around the 800 mark. Then the RB25DE head is 750 with plenum and injectors if you wish or you could use a RB20DET plenum and injectors. Use the RB20DET turbo exhaust manifold and you are off with a fresh motor.. :)
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
