Manifold's From Ebay
The bumper you're talking about looks like this: Rear wing is this different version which is more GTR-esque: -
Thanks I'll keep that in mind when I start digging into that job.
To do the ones around the fuel tank, as in the external ones, you'll likely want a hoist, and to drop the tank. That's the way I'd do them again anyway.
Is the 650rpm idle on the rb25det neo for stock cars only? I've never had my car before and after tuning it to idle at 650rpm when cold. Always idle's cold around 1100rpm, and then drops to about 900-950rpm. I've heard the r33 gtst's idle there.
Series 1 RB25DET 5 speed gearbox, push type, 1st and 2nd gear syncros worn, may need bearings. Comes with quick shift, Tomei gear knob, release fork, bearing carrier, master and slave cylinder. $850. Cusco Super Single clutch,assembly, 225mm, used, comes with a Direct Clutch solid centre 5 puck ceramic clutch plate. $290. RB26 cams used, excellent condition. $280. HDI GT2 intercooler, excellent condition, has 3 inch piping welded to inlet and outlet. $250. All items located in South Eastern Melbourne. Please PM me if interested.
