ok heres the deal i beleive the car im getting from Japan has an aftermarket exhaust system but i want to get a new one for it when its here in Aus. I know there are tonnes of threads on this shit, but its mostly diff questions... I think :D
Q1:Im tossing up whether its worth going an Aftermarket Exhaust system or go to ET(or other SA exhaust specialists) and get a custom done? i know customs are cheaper, but performance and sound wise what are these like?
Q2: Does having an extra 50mm in length from the 4 doors, cause any trouble with aftermarket exhausts fitting wise?
Q3: I am wanting to have about 150 to 170rwkw as a goal, what is recomended to get done to the exhaust system, how much should i spend on exhaust system instead of other performance parts??
I think there is other stuff but ill put it up later.
Edited by nisskid
https://www.sau.com.au/forums/topic/99863-exhaust-options/
q1: it would depend on the quality of the custom system obviously . a known aftermarket system is atleast proven
q2: on the r33 sedan the exhaust fits but sits foward in the rear bar . on my r34 sedan the 2door exhaust doesnt fit and had to be modified , a small section of 3inch pipe was welded into it . no big deal eitherway . even if it does fit like the r33 4 door you may want to extend the exhaust to the proper length so it looks correct .
q3: you want a full 3 inch mandrel bent turbo back exhaust , that means dump pipe , front pipe , hi flow cat converter and cat back exhaust . Additionally you want one with the straitest path and least restrictions with a sound level you can tolerate
check out justjap and their x-force exhausts , for the price they are pretty good . bit loud and droney but perform very well
cost wise full turbo back with cat should cost you 800-2000$
Edited by arkon
https://www.sau.com.au/forums/topic/99863-exhaust-options/#findComment-1819348
You are obviously looking for a mild steel for under $1000, over $1000 for stainless.
You might be able to get some jap kit for approx $1000 in stainless 2nd hand or new.
But thats always without a 3" cat.
If you only want 170 anyhow, just get it locally made from Mild Steel.
Will cost $1000 tops including front pipe and a cat, will be resonably quiet too
https://www.sau.com.au/forums/topic/99863-exhaust-options/#findComment-1819815
Yeah dude common myth that coupe exhausts won't fit 4 doors. They'll fit, it's just that there is one rubber sleeve which doesn't meet up with the 4 door. So hunt around.
I've got a custom one and with the right mods, manifold, cat etc it sounds fu&*ing SIK!
So don't fooled into spendng large amounts of $$$ for a brand name exhaust. Just got to do the right things to get the right noise!
https://www.sau.com.au/forums/topic/99863-exhaust-options/#findComment-1820293
I had D&T do my exhaust, full s/steel turbo back with a 3" s/steel tip, no milo tin style. Sleepy looking.
BUT.. They stuffed my dump pipe, the bloke who made it had NFI, he didn't stretch the pipe over the flange correctly resulting in a 10-15mm V type rise smack in front of the compressor wheel, where as it should be flat then follow the dump pipe down smoothly.. If that makes sense.
I'm taking my car back to them soon to have a s/steel center muffler fitted and the resonator removed, help quieten it down a little.
I'll also get them to do a back to back dyno run to see what sort of power drop there is. I doubt there would be much as its a nicely made 3" straight through muffler.
Edited by Cubes
https://www.sau.com.au/forums/topic/99863-exhaust-options/#findComment-1820359
hmm i love the jap brand exhausts but i dont really think you budget is there for a full jap system maybe x force is the go for you, going from what ive spent on my exhaust 1000 wouldnt get close and from other friends systems too they where anywhere near 1000,
for instance just my cat back cost 950 its a blitz and its excellent the only thing i would maybe choose over it would be a trust system one of there racing ones then, you still have to add the cost of high flow cat front and dump pipe onto that!
https://www.sau.com.au/forums/topic/99863-exhaust-options/#findComment-1820504
I paid $1600 for mine. :S
Mild steel was quite a bit cheaper. There were other exhaust shops and second hand jap exhausts. The problem was I didn't like what every one else was offering.. Milo-Tins. :P
Edited by Cubes
https://www.sau.com.au/forums/topic/99863-exhaust-options/#findComment-1820656
I'm having the center resonator removed and a s/steel muffler slapped in its place, $250 D&T want. Should bring it down quite nicely.
Since the slightly larger turbo went on its fairly loud, not too lound but too loud for my liking. I prefer a quiet car where I can give it stick and ppls won't instantly look over.
https://www.sau.com.au/forums/topic/99863-exhaust-options/#findComment-1823361
is there anyway of having an exhaust system that has a low db idle, but roars when u get the revs up a bit. whats the best way to get this??
Get an adjustable exhaust valve....
A'pexi ECV.
Don't know how good they are, only that they exist
https://www.sau.com.au/forums/topic/99863-exhaust-options/#findComment-1823970
Mine is very quiet on idle and light throttle.
The car next to me with the window up my car cannot be heard.
Give it a boot full and you hear a roar.
BUT its still too loud for me, I want as quiet as I can get it without causing too much of a restriction for up to 280rwkw.
Mild and s/steel also have a slightly different sound.
S/steel drones a little more, mild tends to be just that little bit quieter.
https://www.sau.com.au/forums/topic/99863-exhaust-options/#findComment-1825286
32 sedan and coupe are the same
Good brand name systems can be under 1000
check out trust and blitz systems for 800-900 at autobarn, cartoys etc.
And with that goal in mind, an exhaust will be one of the major modifications.
https://www.sau.com.au/forums/topic/99863-exhaust-options/#findComment-1825522
    • Speaking of diverting threads, my second ever NISMO purchase…. I think they look pretty classy and just wanted to share 😅   PS: 1st was the oil drain plug 😂
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
