As title says not to sure about whether this is really needed.
currently looking at setting up the car with required support mods before i do the next step...
car already has high flow cat, pods, 3.1/2exhaust and split dump.
currently looking at:
z32 afm
pfc
fuel rail
600-700cc injectors (not sure which i need)
oil pump
fuel pump
then thinking plenum and/ or cam kit
next step will be the turboes and internals...
what else is required??
any suggestions and rough power gains...
https://www.sau.com.au/forums/topic/99882-nismo-plenum/
as i said i was looking for support mods at present. didnt think it would make much difference considering the power i want. then again a fuel rail is pretty pointless as well considering nismo injectors fit standard rail with no modification (or as far as i was aware).
other than the pfc, cams where the next main thing. any suggestions? also other bits needed...
https://www.sau.com.au/forums/topic/99882-nismo-plenum/#findComment-1820760
