Im planning on changing my R33 stock box air filter to a Apexi Power intake pod filter. After opening the box and taking the panel filter out, connecting to the box and the afm is 4 gold bolts with a gold mesh filter, the gold bolts are welded on to the frame. The only way of opening it is to either break the bolts and destroy the mesh filter or go from behind which leaves me in this tight space with limited tools = impossible. The afm to the tube is factory sealed which i do no want to break open. What should i do??? Break the bolts??? or is there an easier way?
Thanks!
Edited by cjlancer
i understand wat you mean on the inside of the air box where the nuts are welded is like a funnel to the afm and yes those bolts are hard to get off sooo what you do is at the end of the afm where it joints to the rubber pipe that goes to the turbo there is one of those round jigglers that you screw to do up undo that and unclip the afm unscrew the bottom of the airbox and take the whole lot out and undo the afm that way easy! remember the apexi filters have no joiners just screw straight to the afm! lol remembering thread from last week feew!
cheers simon
I get that its easier to take the box out from the tube to the turbo but i think i saw a seal from the tube to the afm. Should i break that seal?
Plus also does anyone know if ill use more petrol after installing a pod air filter?
Also if the whole engine was stock what sound would i be making after having a pod?
Thanks!
hmm i dont remember any seal lol is it like a sticker to show it hasnt been tampered with kind of thing? i wouldnt worry though look how many people have put pods on i dont think that seal worried them lol!
as for the petrol side i know when you put high flow panel filters on the give you better Economy but i doubt it would make that much difference.
it will be easier to undo the afm o ring and remove the afm and airbox from the car and then unbolt it in your bedroom or workbench instead of the engine bay
lmao. in the bedroom. thats funny as. :lol: :lol:
agreed. The botls are welded on one side. You just take them off from the other side.
Removing the airbox is a piece of cake. Once you've done it a few times, you'll know what I mean. Basically there are about 4 bolts holding it down, and 4 bolts holding it to the afm.
The bolts holding it to the car should be undone first. Undo the hose clamp on the afm. Then you can just pull it off then unbolt the afm from the airbox outside of the car.
it's a piece of cake. You shouldn't have any troubles at all.
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
