Hey guys, first off im very new to the Skyline Scene
and i still have much too learn.. so problem below
will be tried to explain best i can.
After taking the car outta the garage this morning i noticed
i had a big leak.. after inspecting i found it to be
next to the passenger side rear wheel
( Which i believe is the control arm.. the leak could be from correct if im wrong)
The liquid spilled out is of like a silicon base (very sticky like glue)
Is anybody able to enlighten me of my problem? and what it could be?
Car is a R32GTS-T
Any info if much appreciated.
Dave
Car is a R32GTS-T
Dave
Hi Dave, sounds like a rear subframe bush, one of the bushes marked with a green dot on the following picture;
:huh: cheers :(
:huh: cheers :(
Yeap thats it, its coming from the lower right hand green dot.
Thanks guys for all your help.
The trouble will be trying to find a place thats open/or ill have till wait after new year, unless someone could help me out?
Will it be okay for me to drive the car..?
Also on a scale from 1-10, will it be possible to change it myself..?
considering i do have abit of knowledge around tools.
Most people don't bother changing the subframe bushes, you have to remove the entire rear subframe/suspension/diff to do it. The most common fix is to clean the silicone fluid away and fit a Whiteline rear subframe alignment kit (pineapples). These fit over the standard bushes and don't need the subframe to be removed. About 30 mnutes to fit, following are some pictures of a Stagea rear end (basicaly the same) wiht numbers that line up with the WHitleine instructions;
Subframe alignemnt kits are available on the the Group Buy for $110 delivered;
http://www.skylinesaustralia.com/forums/in...showtopic=85591
Hope that was of some help
:huh: cheers :(
:( cheers :)
Yeap that was very helpfull and appreciate it heaps.!
Only x1 thing would concern me getting the Alignment Kit would be that since the bush went ive got this strange sound coming from the rear... very hard to describe but im guessing the sound
is coming from the bush/area. the sound isnt loud at all, and more sound like something is unstable etc..
Perhaps its something else i need to get checked out..
But as mentioned it is pretty strange only happened ever since
the bush went.
Fitting an alignment kit, im guessing would help rid of this sound??
( sorry i get all paranoid when i start to hear wierds sounds etc.. )
I checked out the link for the Groupbuy.. thanks for that :)
would it be possible to reduce the turn around time of 10days delivery?
i wouldnt mind paying abit extra for the freight. Just would rather get it fixed asap
Thanks for all your help SK, once again much appreciated.
the bush went.
I checked out the link for the Groupbuy.. thanks for that  :(
The subframe is most likely twisting, as it has 3 working mounts and 1 not working. It is quite common to simply fit the alignment bushes, they sandwhich in between the standard bush and the mounting bracket. So they become the limiter in travel, taking the load off the standard bushes.
Whiteline are back on the 4th January, so delivery on the 5th is possible.
:) cheers :)
:( cheers :)
No problems at all, i will get you to organize the sub frame alignment for me
Ill take it to PM
Cheers,
Dave
SK, how many bolts should I need to undo to install the front pineapples in the "Maximum Traction" position? I've undone the 2 nuts holding the subframe in place, but the whole assembly doesn't seem keen on dropping (pivoting) so I can insert the pineapple. Tx
Pull it down.
When i did the front ones, i had to remove the whole mount to fit the bushes.
For the rears, i did the max traction one and just lifted the entire subframe with a jack, slipped on the bush and washer, then tightened.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
