  • Replies 63
I can see how the novelty of being able to dial up boost would ware off very quickly. This would also save me $$ to spend on other things.
Say i buy the PFC without the boost solenoid then tune it to a "safe" PSI. What would be a "safe" level for my car as i have done no engine work. only FMIC, ZORST, POD FILTER. I've found 12PSI to be the most common answer but then occasionaly 14-15. Does anyone else with similar mods run the higher boost???
Ive got the PFC boost controller with 3 boost settings. On hot days i change to a softer boost setting. On cool days or when im out cruising with the boys, i select high which is 20psi. Ive got a an aggressive tune so with high boost i do see some knock (60+). On a hot day i would certainly hate to select high boost.
As far as in gear boosts variations, this would be a handy feature to some high powered cars. With my old 255/40/17 Sumo's this would have been nice in the first 2 gears. But i bought some Street R compound tyres and now i get full traction in any gear.
My 2 cents worth.
if you (or anyone) was able to get their airtemp sensor working you can use the air temp vs boost correction table in the powerfc, you can see these settings via datalogit. in fact theres a few tables for boost correction that you can't see on the hand controller which datalogit shows you. such a shame we cant get the airtemp working
please tell me who has it working on rb25det powerfc
I was referring to the rb20det pfc, as it uses the r32/r33 GTR power fc (just remapped by AP engineering) That is why it displays the air temp on the rb20 hc still.
I dont know if the rb25det displayes air temp on the hc, as i dont have a rb25 pfc.
Obviously the rb25 uses its own pfc version, not a remappped gtr item, so it wont have this option available.....
hey sorry, i knew rb20 has sensor display and works if you plug it onto the ecu. the rb25 ecu has this menu item as well, and all the tables and it just displays airtemp as ---. i tried to hook it up and fried my ecu doing it so thats why i was keen to hear from someone who has done it on rb25.
My 2 cents worth.
Should i assume that uve done engine work to be running 20PSI?? that sounds like pain for stock internals. I would only look to have 2 boost settings if i set this up. id prob want 9PSI as low boost and 12PSI for high. i'd be too worried about doing damage if i went higher than 12.
Edited by GTS4dood
i believe this thread should be kept open for general apexi powerfc chit chat as there seems to be enough to warrant its own thread.
ive just noticed that nengun has listed the mainstream powerfc pro as discontinued and only ap engineering customers have acccess to pro options
> Please note: Recently Apexi have stopped producing a number of Pro Spec > PFC`s and H/Cs. Please do not purchase a Discontinued Product.
standard rb25det powerfc pro is no longer available, like the others
Anyone know how to brighten the lights up on it?  In the day light its very hard to read.
dont leave it in the sun, the screen will fade and just get worse, put it somwhere where a shadow casts on the screen
OK, there seems to be a fair few ppl out there that have the Power FC installed. Ive read a FAQ on here that the avg price for tuning is 300-500. im gettin quoted from 450-700. I live in newcastle. so im willing to go to sydney for example to get it tuned if someone can recommend a quality tuner at a good price. a 4wd dyno would be good too. but i can switch it to RWD. would there be much of a difference in the overall tuning???
most tuners are telling me to get a seperate boost controller i.e. AVC-R. im almost being warned off the boost controller kits that apexi make as an add-on for the power fc. why would this be as ive had ppl on this thread say that they are fine?
the apexi powerfc boost contorller kit is fine and works fine.
ive heard mixed reports about the avc-r. the avc-r is very expensive. the powerfc kit is half the cost and gives the same functionality.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
