its alright for you guys....what about us guys that are on the tools.....i would rather it be raining!
find yourself a better union, our site guys only have to work if its exactly 24 degrees... :huh: don't even mention rain!!!!
on a different note tho, spare a thought for us fools who have metal gear shifters, its like touching an iron every time you need to change gears!
https://www.sau.com.au/forums/topic/99974-go-summer/#findComment-1821534
get some gloves then pansy boy :huh: lol jk
i have a GREX shift knob and yer.. gets quite hot if the cars out in the sun, but all the more excuse to practice my speed shifting techniques :lol:
https://www.sau.com.au/forums/topic/99974-go-summer/#findComment-1821547
haha so true!
I have one of those Razo shifters....arrgh.
Also, i reckon 38, 40 is just too hot.
It's too uncomfortable.
https://www.sau.com.au/forums/topic/99974-go-summer/#findComment-1821620
Impul shiftknob... teh sock in the glovebox trick works for me.
https://www.sau.com.au/forums/topic/99974-go-summer/#findComment-1822547
Thank god it won't be 40, you're all insane..
How can any of you people live in Melbourne, be climatised to the cold and look forward to 40 deg heat? Anyway the weather channel isn't a good indicator until like the DAY before.. and even then.. where were those thunderstorms I was promised!
I don't mind a nice beach cruise on a nice day, if only there were *nice* beaches down here!!! Might have to move back to Syd :)
I'm so stealing that idea Munkeh. Pink socks it is.
https://www.sau.com.au/forums/topic/99974-go-summer/#findComment-1823075
yeah, leewah, i got golf on tomorrow too! Time to crank out those long drives in the heat :( Where ya playing?
Watch the coppers tho if you plan on some beach crusing. Undercover SILVER and DARK PURPLE, SS Commodores. The new models. Plus marked cars cruising as well. Lots of cops down this way on the nice hot, cruising days.
Bring on Sunday i say... there is a limit and 42 is waaay past that limit.
https://www.sau.com.au/forums/topic/99974-go-summer/#findComment-1825520
Watched the purple one chasing a bike on Beach Road a while back and then a very angry policeman pulling a bike that was behind me over further up the road as the first one had got away. Dont think they were even together. Then saw the silver one about 2 weeks ago having pulled a truck over in the morning rush near the Caltex on Beach Road.
https://www.sau.com.au/forums/topic/99974-go-summer/#findComment-1825637
    • I figured out what’s wrong. It’s something to do with the high beam wire short circuiting. When I measure the continuity with a multimeter on the headlight socket connector it gives me a continuous beeping noise when I put it on the ground socket and also on the high beam socket.  On the passenger side of the car (working side), it’s only beeping when the probe is on the ground socket. Which makes sense.  So that means it has something to do with the high beam power supply for the drivers side. How do I trace that? Is it the turn signal lever malfunctioning? The one that also controls the high beam and low beams.
    • Hey lads just finished tidying up a gtr a bought. Originally from Sydney now living in New Zealand
    • Hi Guys, Looking for this piece if anyone can help out.   https://tfaspeed.com/products/nissan-skyline-r33-gtr-rear-trunk-finsher-panel
    • How did you go with your problem? End up fixing it. Have a y34 aswell vq30det
    • But if I smoke test 5th cylinder it’s all ok, no leaks  when I try with 2nd it’s leaking exhaust and intake, it doesn’t come from oil dip stick.    so maybe when car was running poorly, rich or sth. Spark plugs were black and covered in charcoal or sth lookalike. could potential contamination make valves not seal properly? is there also a possibility that rb’s don’t have equal performing cooling passages  meaning back of the engine will be hotter than front. Can this cause improper wear if engine was running under load for short time? Or carbon build up could just burnt from 4-6 and is still on 1-3?   I out of my head like really. Timing is as manual crank-exhaust 47, exhaust-intake 38 at this point I thinking about give it a try and make another 500-1000km and check if anything change, if not I will most likely disassemble engine head /or whole engine and send it back to rebuild. It’s killing me
