hey guys ive got a R32 ball bearing T3 turbo for sale that i no longer need.
its has no shaft play other than the natural little bit of forward to back (2mm) that you get with ball bearing core.
absolutely NO side to side shaft play, ie a PERFECT condition turbo.
only done 65,000k's on stock boost for 60,000 of that, and 10pound for the other 5,000
will NOT be dissapointed
absolutely NO cracks at all in this turbo, ie none on the exhaust housing near the wheels like most T3's have, and none at the wastegate port.
comes with actuator aswell.
in SE melbourne suburbs, and you can have a look at it before you buy.
looking for $320 ono as i want to sell asap.
reason for selling is that i purchased this for an mx6 conversion, but i have picked up a manifold to suit a wrx turbo.
here are some pictures of it, note it has a slightly polished compressor housing!
will bolt up directly to standard manifold not a problem!
contact me via email on [email protected]
or pm me.
or call me on 0423 054 117
ta
https://www.sau.com.au/forums/topic/96256-r32-ball-bearing-turbo/
2mm is A LOT of play dude...
you sure it still works!?!?!
i know there is sposed to be a tiny bit of play but its sposed to be like 0.5mm
u on drugs mate? 1-2mm is normal for any turbo, by no means is it alot
i thought ball bearing is standard on most if not ALL RB series turbo.
as was 10psi....coz thats teh wastegate actuator is rated at.
there should be any in and out for ball bearing with no fluid ..... far as i know. my r31 turbo is ball bearing ..has no in out or any side to side and has done nearly 175,000kms
dude they are ceramic turbos on rb series not ball bearing ?
there ceramic ballbearing turbo's.on r32 and so on.
what the hell are u on about?
as merlin and a few others have already said.. stock R32, R33 and R34 turbos are ALL ceramic NOT ball bearing.
wtfs a ceramic ball bearing turbo?
why do you think the most common upgrade is TO a BB turbo like the VG30?
most of the rb turbos ARE ball bearing. then you have the occasional one that has cooling fins in between the two housings that are bush bearing.
that turbo has no cooling fins and is therefore ball bearing
by ceramic people mean that the rear wheel of the turbo is ceramic and thats why you cant run more than 1 bar without the wheel shooting off.
ceramic has nothing to do with if its ball bearing or not.
far out, some people shoot there mouth off without having any idea. All the r31 rb20's were bush bearing aswell as the series 1 r32 rb20's series 2 R32's and onwards are all ball bearing and all have ceramic exhaust wheels i believe standard!
yes sorry... i take that back and apologize... VG30s have a steel wheel which is why most people upgrade to em... unlike the ceramic RB20/25 Turbos.
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
