hey guys ive got a R32 ball bearing T3 turbo for sale that i no longer need.
its has no shaft play other than the natural little bit of forward to back (2mm) that you get with ball bearing core.
absolutely NO side to side shaft play, ie a PERFECT condition turbo.
only done 65,000k's on stock boost for 60,000 of that, and 10pound for the other 5,000
will NOT be dissapointed
absolutely NO cracks at all in this turbo, ie none on the exhaust housing near the wheels like most T3's have, and none at the wastegate port.
comes with actuator aswell.
in SE melbourne suburbs, and you can have a look at it before you buy.
looking for $320 ono as i want to sell asap.
reason for selling is that i purchased this for an mx6 conversion, but i have picked up a manifold to suit a wrx turbo.
here are some pictures of it, note it has a slightly polished compressor housing!
will bolt up directly to standard manifold not a problem!
contact me via email on [email protected]
or pm me.
or call me on 0423 054 117
ta
https://www.sau.com.au/forums/topic/96256-r32-ball-bearing-turbo/
2mm is A LOT of play dude...
you sure it still works!?!?!
i know there is sposed to be a tiny bit of play but its sposed to be like 0.5mm
u on drugs mate? 1-2mm is normal for any turbo, by no means is it alot
i thought ball bearing is standard on most if not ALL RB series turbo.
as was 10psi....coz thats teh wastegate actuator is rated at.
there should be any in and out for ball bearing with no fluid ..... far as i know. my r31 turbo is ball bearing ..has no in out or any side to side and has done nearly 175,000kms
dude they are ceramic turbos on rb series not ball bearing ?
there ceramic ballbearing turbo's.on r32 and so on.
what the hell are u on about?
as merlin and a few others have already said.. stock R32, R33 and R34 turbos are ALL ceramic NOT ball bearing.
wtfs a ceramic ball bearing turbo?
why do you think the most common upgrade is TO a BB turbo like the VG30?
most of the rb turbos ARE ball bearing. then you have the occasional one that has cooling fins in between the two housings that are bush bearing.
that turbo has no cooling fins and is therefore ball bearing
by ceramic people mean that the rear wheel of the turbo is ceramic and thats why you cant run more than 1 bar without the wheel shooting off.
ceramic has nothing to do with if its ball bearing or not.
far out, some people shoot there mouth off without having any idea. All the r31 rb20's were bush bearing aswell as the series 1 r32 rb20's series 2 R32's and onwards are all ball bearing and all have ceramic exhaust wheels i believe standard!
yes sorry... i take that back and apologize... VG30s have a steel wheel which is why most people upgrade to em... unlike the ceramic RB20/25 Turbos.
